  1. I have recently upgraded to broadband so I now have lots of downloaded mpegs that I would like to burn to vcd.
    I have sony WIN-ON software which is supposed to be straightforward.
    Whenever I drag and drop mpegs into the software...they are rejected because of something called an "invalid muxer rate".
    I am a big music fan...and now have loads of music vids on mpeg that i cant burn.
    I would be grateful if someone could tell me what to do next!!!
    Thanks!!
  2. Hi
    All I use, indeed all I've ever used, for burning VCDs is Ahead Nero. Its pretty good. Why don't you give it a try?
    Kind regards
    Alan
  3. The files are probably not VCD compliant--not all mpg's are compliant. You may need to reencode them to the correct PAL or NTSC settings before you can burn them (check guides on this site). No software can burn them as a VCD if they aren't in the correct, compliant format.
