    Oct 2015
    Bhokraha-01, Sunsari ( Nepal )
    i want to change Video Extension
    any format to 3gp / Mp4 / mkv
    Without Re-encoding
    I have avidemux and video container Changer
    that haven't 3gp option
  2. MKVMergeGUI
    Video To Video Converter (use the Direct Stream Copy conversion preset)
    Sep 2012
    Australia
    3gp and mp4 are essentially the same thing
    They're each limited in the actual codecs they can contain. If you want to turn anything into an mkv without re-encoding you use MKVMerge.
    MP4 generally only takes AAC audio (maybe AC-3) and mpeg video. It does take others but you're unlikely to find those other codecs in non-mp4 files.
    Any format to mp4 without re-encoding is a hard ask, the source would have to contain the right codecs to begin with.
