I just made a DVD of a slideshow in the top three levels of quality given which were best with bit rate about 9,000, good with bit rate about 6000 and standard with bit rate of about 4000. I could not believe that bit rate would effect slides but it does. In the standard level, some of the slides flicker. In the good level there are little dots in the image that flicker and in the best there is no flickering. I cannot understand how the bit rate could effect nonmoving slides.
There shouldn't be much difference in a slideshow with no transitions/panning with those bitrates. What software are you suing? Maybe it's doing something else different. Post samples.
Bit Rate minimums sure reduce file size but still keeps quality
By johnharlin in forum Video ConversionReplies: 2Last Post: 18th Jul 2015, 09:34 -
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30 -
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 22:56 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 22:00 -
Help Reducing Bit Rate on video
By Aleahsmom in forum Video ConversionReplies: 2Last Post: 28th Apr 2011, 14:47
