I have The Doors Perception 5.1 DVD-A of The Soft Parade album that I ripped and made my own custom two-track mix. I ripped it at 24/96, and want to put it back on an audio dvd at 24/96, or maybe it's called DVD-V? I thought I could use Roxio like I have for other audio-only dvd's. In the past I must have used 16/48 because I've never had a problem. I get a message that says "this file is not supported" I'm guessing it's because the file is above 16b and/or 48k? I did select the "create dvd music discs" option.
Does anyone know what the quantization limits are for Roxio NXT Pro? I tried to find it, but got nowhere.
I don't need any menus, video, or pictures. I burned a cd at 16/44, but also want to see how it sounds at the full rez.
I do have Sony Vegas Pro 12, but the highest sample rate output it shows is 48k. I thought about just making the dvd that way.
I tried downloading Lplex, but didn't have much luck unzipping everything.
Is there a newer, better version of Roxio? I admit I'm a little slow when it comes to using new programs.
Results 1 to 1 of 1
Audacity 32bit 96k to 16b 44k?
By clashradio in forum AudioReplies: 33Last Post: 2nd May 2014, 06:59 -
Roxio game capture hd pro and graphstudionext
By Milardo in forum Capturing and VCRReplies: 9Last Post: 10th Jan 2014, 22:34 -
amarectv and roxio game capture hd pro
By crazycoyote in forum Capturing and VCRReplies: 5Last Post: 24th Nov 2013, 15:34 -
Roxio Creator 12 vs Windows media player 12 (Windows 7)
By Mathan82 in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2013, 08:31 -
Roxio Media Creator Suite 10 Stange Results
By DB83 in forum Authoring (DVD)Replies: 7Last Post: 16th Dec 2011, 12:53
