I've been transcoding movies for about 4 years now, and have finally worked out a style, where
in the second pass, I purposely create a letterbox with approx 40 pixels top and bottom, using VLC.
Then in the third/final pass I use VLC to I place a title and progress/duration info and a logo up top,
and burn in sub-titles in the black area at the bottom.
To achieve that, I use VLC cmd-line, because it supports padding and on-screen text (marquee and logo, etc).
[ I use FreeMake for the first pass, to initially obtain the desired standard resolution. ]
Then, this past week, I came across StaxRip !
[ I''ve played with it for about 8 hours now, and it definitely "feels right". ]
It's UI-design appears to be head-and-shoulders above the competition !
Clearly, it has the most transparent and easiest to use GUI of all the
transcoding tools out there.
The one improvement I've been seeking is to find a tool that could combine my
first two passes into one.
I was hoping that StaxRip might be up to job, but I can't find any way to force it to
CREATE black bars. (Am I missing something?)
[ I've concluded that its design philosophy must be predicated upon the (erroneous)
notion that no one would WANT black bars. It has a CROPPING filter...but it needs
a PADDING filter, in my view. ]
Any chance a padding-filter could be implemented in StaxRip???
Cheers...
-- SarasotaSlim
(VLC rules, but StaxRip and FreeMake are certainly contenders) -
(don't use StaxRip, but) iirc. StaxRip does allow to modify the avisynth script it uses, so you could use AddBorders (http://avisynth.nl/index.php/AddBorders)
4.3 video letterboxing
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 1st Nov 2015, 06:10 -
how add padding to the sides of a video ?
By dcaro in forum EditingReplies: 10Last Post: 13th Aug 2015, 13:10 -
Why is padding used in videos/movies ?
By devvaibhav in forum Newbie / General discussionsReplies: 16Last Post: 12th Aug 2015, 19:12 -
Hard Coded Letterboxing
By danielnitschke in forum EditingReplies: 4Last Post: 6th Jul 2015, 01:30 -
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 18:56
