There have been various std def cams that shoot in 16:9. Wondering what the manufacturers envisioned as the playback device for SD 16:9? If there's ever been a SD widescreen tv I don't recall ever seeing one being sold in the boxmarts. I don't recall seeing widescreen tv's appear in stores until HD was being marketed.
Results 1 to 22 of 22
It was common in Europe - especially for CRT's above 28'.
Most of broadcasters switched at beginning previous decade to purely 16:9 anamorphic transmission, earlier in Europe quite popular (albeit limited anyway) was various MAC https://en.wikipedia.org/wiki/Multiplexed_Analogue_Components formats and some of them promoted 16:9 as native. -
I know either LCD or Plasma 16:9 TVs existed in the late 90s. They probably were not cheap. I only know this because John Malkovich had one in his house, in the 1999 fictional movie "Being John Malkovich". He was watching normal 4:3 video, boxed in a 16:9 flatish TV.
Yes. Plenty of 16:9 CRTs over here. We had a Sony.
That being said, there was a distinct lack of 16:9 programs in the early days (since 4:3 CRT were still in the majority) so one ended up with stretched picture. -
SD in anamorphic 16:9 started becoming broadcasted in Germany in larger percentages in around 2006-2009 (depending on the station) and is still way more available than HDTV to this day. This was somewhat late for 16:9 CRTs, though.
Good thing however is (apart from some crappy stations) this did not lead to an end of real 4:3 broadcasting, meaning old shows are still broadcasted as they always were in 4:3 – so the aspect ratio adaptively switches between 4:3 and anamorphic 16:9 on the fly. Analog broadcast is letterboxed when needed. -
European broadcasters using usually WSS https://en.wikipedia.org/wiki/Widescreen_signaling to signal source aspect so no need to letterbox (unless broadcaster is not pro)
What display was std def 16:9 intended for?
There was or still there are millions of 16:9 DVD's watched on 4:3 CRT's all over the World. Same thing. Image is not degraded. It is just smaller or bigger depending on TV.
Black bars are irrelevant problem, mostly created with our brain. One can have 50" TV and watching letterboxed 4:3, with no problem, other person things something is wrong.Last edited by _Al_; 31st Dec 2015 at 17:03.
An image on a 4:3 screen will not have a degraded screen since it will have all the pixels intended for the viewing area,what will be missed is the side views,your argument is wrong.
Geez, by following your line of reasoning to its logical but ridiculous conclusion a 1.33:1 source should be viewed only on a 1.33:1 ratio (4:3) television, a 1.78:1 source only on a 1.78:1 (16:9) television, and a 2.35:1 source only on a 2.35:1 (21:9) television. A different television for every possible video aspect ratio because, after all, by doing it any other way 'you're not using all the pixels (and) you're getting a degraded image'. That way the TV 'real estate' is put to its fullest and best use. Next you'll try and justify 'pan-and-scan' as being the proper way to view films on a 1.33:1 (4:3) television because it uses the entire screen and doesn't have black bars. And if you're one of those people that crops his 2.35:1 movies or uses the zoom to remove the black bars so you don't have to see any black when watching on your television, then there's no point in even discussing this with you.
As _Al_ said, "Image is not degraded. It is just smaller or bigger depending on TV." And for the kinds of video you were speaking of (widescreen but standard-def cams), this was still during the days of CRTs, mostly, so pixels didn't really come into play then. -
You're apparently willing to expend a lot of energy to try and defend an incorrect statement. A letterboxed 16:9 image on a 4:3 screen is not using the same number of pixels it would on a 16:9 display and as a result is degraded. You can parse and dance and cite specs until the cows come home, you'll still be wrong if you state otherwise.
At what resolution (assuming it was digital), then, did your long ago standard-def camcorder shoot? 854x480, or some such? And you're viewing on what? A choice of 1440x1080 (4:3) or 1920x1080 (16:9) LCD or plasma displays? And the 4:3 one when showing a 1.78:1 video will display at 1440x810 or thereabouts, right? With the rest being black bars? But the original height of your video was 480, and the height of the video on the television is significantly greater than 480. On one television you interpolate vertically from 480 to 810 and on the other from 480 to 1080. You're upconverting so what's being 'degraded'? My guess is that the quality of the picture is based entirely on the quality of the scalers used in either the players or the televisions and not on whether one television is 1.33:1 and the other 1.78:1 and not on whether one television upscales to a higher vertical resolution than another. You can throw as many pixels as you like at it, but in the end it's still from a 480 pixel-height source.
I know, but for analog broadcasts the video has to be letterboxed even though WSS is used, simply because you cannot assume all TVs receiving the signal are new enough to understand WSS and squeeze the picture automatically on their own. To aid this PALplus was utilized, but it's dead nowadays. All remaining analog broadcasts are simply plain letterboxed when needed (which is probably 98% of the time).
It seems we are missing a vital detail in this discussion until now.
This statement is valid only if the anamorphic 16:9 image is displayed on a 4:3 TV by hard-letterboxing it beforehand (like resizing it and then adding letterbox bars so that the frame becomes 4:3 before the signal even enters the TV).
However, if you let the TV switch into 16:9 mode it squeezes the image by itself which does not lose resolution.
Pretty much all CRTs TV in Europe since the mid 90's can do that, either via Scart Pin number 8, via WSS or manually with the remote (usually all three).
Besides, a CRT does not have any fixed pixels whatsoever!
It displays any signal in any proportion you want it to losslessly (well, until the dot-pitch of the shadow mask or aperture grille (Trinitron) becomes too coarse and you actually start losing some res, but this is not the case for the scenario we are talking about).Last edited by Skiller; 1st Jan 2016 at 06:29.
Well - at first i saw many ZDF and ARD broadcasts without letterboxing so this is not always valid (hardcoded letterboxing).
Second - yes most of the old analogue CRT's TV's with 4:3 aspect CRT modifying Vertical deflection voltage in such way that video is squeezed in vertical direction but number of lines is same as for 4:3 video (from practical perspective Vertical deflection voltage is lower).
CRT tube usually have limited number of the RGB triads in horizontal direction available and by such pixel resolution is limited - this apply also to vertical direction but some of CRT designs have practically unlimited vertical resolution (Sony Trinitron for example) - vertical resolution in this case are limited by CRT gun capability to focus electron beam (which is not so easy).
Side to this special beam processing can be applied to further improve resolution (dynamic focus, Scan Velocity Modulation etc).
Special CRT designs may have capability to individually addressable pixel (similar to CLD/PDP/OLED etc) so they may have native resolution. -
Widescreen is not pixel, resolution issue, for example you say 16:9 is "degraded" on 4:3 screen, but 16:9 is wider, providing wide-angle lens for that SD era was good and not blurry in corners. So you watching that 16:9 on CRT of that time having more things in the frame horizontally or be up close, not needing to step back. With 4:3 you have narrow angle of view. So one might as well think that 4:3 WAS degraded in the first place because you'd need to step back with camcorder and recording less detail in the first place! So at the end you might have more detail in that "degraded" frame as you claim.
You cannot compare incomparable. That 4:3 or 16:9, if done right, would be shot each time differently, so there is nothing to compare, we shoot for what to have on screen, framed visually, you cannot compare 4:3 and 16:9 shot, you imagine that 4:3 just having more information as oppose to that 16:9 , part on the top and at the bottom, but that is not happening. Just imagine going into theater seeing very wide-angle shot. Details of eyes in "Once Upon a Time in the West" movie and then go and shoot that detail of Henry Fonda face with 4:3 camcorder. With camcorder you'd not shot that eye detail in the first place, you'd just got all that face at the end. Nothing to compare.
Imagine looking at it as camera man thinking of shooting a scene.
Other reason just coming on my mind. Today editing 4:3 SD video and mixing it with 16:9 footage, there is no problem with resolution to that degree as with actual 4:3 format. One has to cut off footage to get 16:9. So you have old 4:3 SD footage really "massacred" mixing it with new 16:9 footage. We can see it on our TV's on regular basis how editors and creator (documentaries) deal with that one problem every day.Last edited by _Al_; 1st Jan 2016 at 15:49.
wlmm - video clips display do not display correctly?
By OleMan in forum EditingReplies: 7Last Post: 12th May 2013, 10:32 -
Sony Vegas: Mixing standard Def and Hi def in a video project for Blu Ray
By liberty610 in forum Authoring (Blu-ray)Replies: 39Last Post: 22nd Jun 2012, 03:19 -
High Def for Canopus Let's Edit 2.
By ralphb in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2011, 09:29 -
High def onto a DVD?
By enchant3 in forum Authoring (DVD)Replies: 5Last Post: 17th Feb 2011, 06:17 -
HI Def DVD
By GeorgeD123 in forum Authoring (DVD)Replies: 4Last Post: 12th Feb 2011, 15:56
