Hello,
I have a nephew who is wants the be the #1 minecraft youtuber of all time!In that regard, we spend the 25. dec. putting together his new stationary with a nice mix of new and pilfered parts! Now, I'm new to video recording and encoding, so I spent the following two days understanding the demands of game recording and subsequent post-processing. Now, he only has 8 GB of memory, and recording for 10 minutes will easily exceed that, so I figured we'd encode it with h.264 to make it easier to work with (also, he is using windows movie maker, which doesn't handle the large file sizes). This takes a lot of time after he is done recording though.
So I thought to automate the process. The recording tool can spit out 5 minutes of video at a time, and I thought to write a small code, utilizing an existing h.264 encoder to monitor the output folder for the files. When they appear, I want to put it in a "to-be-encoded" queue, and then start the encoding in a process using all but one core of his CPU, one job at a time. Then spit them out in a new folder and perhaps move the big file to a storage location (so it doesn't clutter up the SSD).
(Side note: He has two GPU's, the one on his main board seems to take care of the recording process. This leaves the CPU relatively free to do encoding work.)
Now, to do this, I'd ideally like to find an encoder which can work with a config file. I've used "ImagesToVideo" to make 3D movies for computational fluid dynamics in C#, and have a framework ready to go. However, I'm a bit lost as to what encoder to use.
I've had a look at videolans h.264, but I couldn't immediately figure out how to work with it. And it looks too much like a core engine where I would have to handle quite detailed arguments. I then looked at ffmpeg, which looks better, but it is quite command line based. Also, it looks like I have to specify a lot about the input format, which I'd hoped the tool could figure out itself.
And this is where I'm at... I'm a bit short on insight into encoders, and would really appreciate any advice/reccomendation! Like... Should I look into h.265?
Closed Thread
Please don't cross post. The video sections works fine. And you do not sound like a newbie...
Continue in https://forum.videohelp.com/threads/376096-Best-low-thershold-scriptable-h-264-encoder
Best encoder for MPEG-2 with low bitrate?
By Observer in forum Video ConversionReplies: 11Last Post: 25th May 2015, 17:36 -
Best H.264 encoder?
By W_Eagle in forum Video ConversionReplies: 68Last Post: 7th May 2013, 13:48 -
Best H.264 settings to target low-bandwidth audience
By AlirezaM in forum Video Streaming DownloadingReplies: 0Last Post: 19th Oct 2011, 14:45 -
(Scriptable) Convert <everything> to mpeg2?
By highend in forum Video ConversionReplies: 2Last Post: 16th May 2011, 14:56 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22
