Hello, My Videoeditor freezes and crashes, what can I do?
It takes a lot of Ram.
Is there a trick?
hello0 ...
Do you need help?
What video editor?My Videoeditor...
Converting? Altogether? Editing function?freezes
How?crashes
Whats a lot? How much you got?... a lot of Ram...
Yes... Maybe... Sometimes... Depends...Is there a trick? -
Unfortunately this seems to be a fault widespread with this editor, at least on the internet. If you go to search 'vsdc free video editor crashes' you find a ton of references to the same things. It references using 30% of your cpu which is about 280MB out of 8 GB and also seems to have a problem with videos longer than 15 minutes?
You might try what several threads suggest:
To fix VSDC from crashing try to set manually virtual memory in windows, or use already cut smaller videos in Video Free Editor.
Reply
To what amount should we adjust the virtual memory? Any help in the process would be appreciated.
Reply
I have it on 2550MB and max. is set to 12750MB. Still without any crash. -
I set it from 4000 to 16000 MB and it still freezes and crashes. Is there another solution?
On my Laptop it does not freeze, only on my PC which has 8 GB RAM, why?
I even have a bigger file with 120 MB in it. On my PC the videofile is 60 MBLast edited by hello0; 29th Dec 2015 at 09:46.
You asked: "Is there another solution?"
My answer: Try another editor.Extraordinary claims require extraordinary evidence -Carl Sagan
Does this VideoEditor have 30 of 60 fps ?
By hello0 in forum EditingReplies: 9Last Post: 2nd Sep 2015, 16:33 -
Studio 14 Closes/Crashes
By TunkaFrankie in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2013, 23:01 -
Handbrake crashes on startup
By sum_guy in forum Video ConversionReplies: 12Last Post: 21st Apr 2013, 11:22 -
3DSubtitler crashes
By cactus_j in forum SubtitleReplies: 0Last Post: 18th Jun 2012, 13:55 -
Xvid4psp crashes
By skorpinok in forum Video ConversionReplies: 1Last Post: 9th Jul 2011, 14:59
