    Apr 2002
    Aussie
    Are there anyone using SmartRipper and FlaskMPEG in combination for ripping and converting DVD to VCD?
    I've been experiencing a weird problem when trying to load the IFO file in harddisks.
    I'm absolutely satisfied with SmartRipper for ripping DVDs, also have the IFO copied to my harddisk as well. But when I tried to load the IFO file using FlaskMPEG, an error always pop up after the selection of angles, audio track and subtitles, and it says "There was a problem while parsing the IFO file. Read the documentation for its possible causes."!!
    I tried to copy the IFO file straight from the DVD to harddisk manually, and the same error comes up. But something weird enough is that if I load the IFO file straight from the DVD, FlaskMPEG works just fine! (except that it's heaps slower)
    Could anyone plz let me know what I've done wrong??
  2. I had same problem couple of days ago I installed this thundersmin and it worked for me here´s the address to that file... exctract it to your flaskmpeg directory. I tested it with flaskmpeg 6 preview.
    Apr 2002
    Aussie
    IT FINALLY WORKS!!!!!
    Thanks HEAPS, mate!!
    U r a savior!!
  4. rip the disc in file mode(not movie mode)
