Hi!
Youtube has this idiotic thing of not letting you uploading an audio file. They recommend using a thrid-party tool, even though they have a slideshow creator. Of course you can't add your own audio for that. What morons...
Anyway. I want a quick way of adding a valid video stream, so that youtube doesn't fail on conversion. It can be whatever, a still image, or even just empty video as long as it can be done fast (no long tinkering, or conversion/upload times) and youtube can handle it.
Does anyone have an idea?
Results 1 to 17 of 17
I tried that one. It converted horribly slowly, even though I set a ridiculously low framerate, so there wouldn't be many frames to encode or to take up space.
I think this might have been the command line:
Never figured out why it took more than an hour (I think) to encode even though there were only a few frames encoded for a three hour video.Code:ffmpeg -loop 1 -r 0.0000001 -i -i -shortest -acodec copy -vcodec libx264 -tune stillimage -crf 0 -g 1 -pix_fmt yuvj444p out.mkv
Well your thinking backwards
What you do is create the video stream the same length as the audio file aka run time..playing time
Then you add the audio to the video
He processes is called muxing ,
After all it is YouTube video not an audio website -
Reading this I wonder, wouldn't it be easier to multiplex the audio and an image into an mp4 file?
or doesn't YouTube support such content? (ffplay and nearly all a/v players out there would show the image while playing the sound)Code:MP4Box -add "C:\Users\Selur\Desktop\Elysian_Bailey_-_01_-_Come_Home.mp3"#audio:lang= -itags cover="C:\Users\Selur\Desktop\Elysian_Bailey.jpg" -tmp "H:\Temp" -new "H:\Output\imageAndSound.mp4"
I guess instead of mp4box one could also use ffmpeg, but since I don't know the ffmpeg command line directly, I prefer MP4Box.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Don't know if you have found your way but FFQueue has a tool for creating a video from images with an optional sound track, screenshot here: http://ffqueue.bruchhaus.dk/gfx/Screen10.png If you do not want to create your own preset you can copy the preset below and paste it to FFQ:
Code://8YAQAAeNpNjk9PwzAMxe+R8h12n4Wc0EGZ5EO5cUQcEaq81B vR+mck6WDfHqtSBQc/W34/P/n9kiRL+bAmdrRt3vqA+blpmhS+ VV5rHYmsGXkQehn4JHlTps01djJZs7Q2TJ0E6uPhxz9U1pzl1h 6T8pkAAKFCFVzhr5n7WG6E8LgDBzuv4p0ST7iyTmGeu/gv+Tq1 zEHGsDqJi5DztV4DrMu/7FojjpxLLpwKOWvK5zwcMi3xcBlPS/ eIWlDBPegv6uHe4R7xDhF/AR35Ud8=
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
I tried this.
Lower framerates for some reason don't work on playback. Get some invalid timestamp errors.Code:ffmpeg -loop 1 -r 0.07 -i <image> -i <audio> -shortest -acodec copy -r 0.07 -vcodec libx264 -tune stillimage -crf 15 -g 10000 -pix_fmt yuvj444p out.mkv
I uploaded some on youtube, but the videos got stuck at 95% processing... -
did you try the mp4 method I proposed?
Did you try FFQueue? The image2 format used by ffmpeg uses -framerate and not -r. For a framerate of 1 frame pr. 5 seconds, try:
EDIT: Output frame rate changed to 25 in the command.Code:ffmpeg -loop 1 -framerate 1/5 -i <image> -i <audio> -shortest -acodec copy -r 25 -vcodec libx264 -tune stillimage -crf 15 -g 10000 -pix_fmt yuvj444p out.mkv
I think I tried this before, but anyway I tried adding cover art with mkvmerge instead. Video players show it without a problem, youtube can't process it.
I use ffmpeg directly. So you mean at the input I should use -framerate? It's surprising, because it seemed to have worked normally until I got too low and something got messed up. (Maybe it's just the players can't handle too small framerates)
What's point of -r 25 for output? That will just add a lot more frames to encode, doesn't it? -
You must use -framerate as input framerate for images. If not 25 will be assumed: https://www.ffmpeg.org/ffmpeg-formats.html#image2-1
-framerate and -r are not the same and they behave differently as input option and output option: https://www.ffmpeg.org/ffmpeg.html#Video-Options
You must use a target frame rate that is commonly supported (at least by ffmpeg and youtube). If you do not your video might fail to encode or produce ill behaviour: https://support.google.com/youtube/answer/1722171?hl=en
You can force a larger GOP-size to lower the file size. Assuming you encode to 25 FPS I would set max. GOP-size to 10 seconds (-g 250) and min. GOP-size to one second (-keyint_min 25).I'm the developer behind FFQueue. My posts might reflect this! ;-) -
I see. It was not my experience though for "-r". When I set it as an input nothing else for framerate, I got identical behavior. And an encode that had the appropriate framerate.
You seem to be right for framerate. when I didn't use 25 processing got stuck. Previously youtube didn't have such problems. I could upload a 3 hour video file with some extremely small framerate.
Too bad there isn't just a simple tool that lets you quickly add an image or slideshow, apparently it's impossible. I imagine the best would be encoding as a single keyframe and all p-frames that reference this frame. (if possible)
Oh well one can dream. I was (ATM) only interested in downloading an ~hour long audio file to see if I can get youtube to do voice-recognition/subtitling. (The answer is no, the option doesn't appear for long videos)
Anyway I succeded in uploading with your settings. But it seems like the high enough input framerate is still necessary, with 1/25 the video gets stuck. I got a blank grey video though. Limiting gop to 250 didn't help -
Sometimes ffmpeg seems to mess up the PTS in the video if you use odd frame rates. You can often get about this by using the setpts filter to set the PTS for each frame:
where XXX is the time each frame is displayed declared as seconds.milliseconds (5½ seconds would be 5.5).Code:ffmpeg ... -vf "setpts=PTS+(XXX/TB)" ...
YouTube HD uploads - 1072 still?
By Voxx in forum Video Streaming DownloadingReplies: 4Last Post: 21st Jul 2015, 10:11 -
Youtube supporting 60fps uploads starting today
By roma_turok in forum Latest Video NewsReplies: 20Last Post: 5th Nov 2014, 13:10 -
Youtube uploads are choppy :(
By CrystalMethod in forum Video Streaming DownloadingReplies: 13Last Post: 7th Mar 2014, 12:12 -
YouTube Playback Issue on Uploads
By Database Ranger in forum Video Streaming DownloadingReplies: 10Last Post: 6th Nov 2012, 16:16 -
Is there any quick way I can compress the audio of a video file alone?
By Unlaminator in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2012, 12:17
