i have an anime video that i want to upscale the thing is i ran into a lot of trouble trying to do so since i am not experienced in this field, i tried using avspmod to add a simple script.
"converttoyv12() aWarpSharp(depth=16.0, blurlevel=2)"
and ran in trough megui and it came all ****ed up with worse quality the sound is fast forwarding and it cropped to 3:4 and not 16:9 like it was originally
my question is simple
how can i apply certain filters and then spit out a new video file which is like the original but upscaled with filters without all the weird stuff around
here is a shot from the video if some experts could recommend other scripts
https://forum.videohelp.com/images/imgfiles/bvjTm8d.jpg
i would really appreciate the help
Hi,
could you first explain what you expected aWarpSharp() to do? Instructions are available here.
Your screenshot is already at 1920x1080, i.e. high definition. Do you wish to upscale it further or did you start out with something smaller originally?
"Filters" aren't a magical cure. You need to examine your video, recognize the issues it has, and choose a suitable filter combination with appropriate parameters.
Combining clips of different resolutions without scaling?
By Gameshow Host in forum EditingReplies: 13Last Post: 21st Dec 2015, 12:14 -
PotPlayer subtitle scaling
By Hahahhaha in forum Software PlayingReplies: 10Last Post: 15th May 2014, 10:16 -
scaling question
By hoodleehoo in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2013, 06:29 -
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 04:10 -
ffmpeg automatic scaling possible?
By richiedood in forum Video ConversionReplies: 14Last Post: 2nd Jul 2011, 08:52
