Results 1 to 12 of 12
  1. hi
    can someone tell me if this is right?
    d/l a small avi film file
    changed it to mpeg using TMPGEnc
    burn it useing super video in nero
    will this work in a dvd player that plays vcd files
    i`m going to buy a new dvd player and want one that i can play my own films if this was right i was going to take the cd to shop and try it there and then
    if not right can someone tell me what i`ve done wrong?
    thanx
  2. In the general aspect, yeah, that could be right, but here is more specific:
    Encode AVI to MPEG1 using TMPGEnc and loading a VideoCD Template, and then burning using VCDEasy or TSCV to create a Standard Video-CD movie
    Encode AVI to MPEG2 using TMPGEnc and loading a SVCD Template, and then burning using VCDEasy or TSCV to create a Standard SuperVCD movie
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. thanx for the reply
    i know this will be something simple but what do you mean by a" loading a VideoCD Template"
    if you dont ask you wont know ?
    thanx
  4. In TMPGEnc, there are pre-defined settings stored in files which are called Templates, you must load one, so it will set the encoding to a specific standard, you can't just encode and expect a file to work, it has to be in a standard settings.
    Best Regards,
    Sefy Levy,
  5. thanx for the reply
    how do i load one of these files
    i opened TMPGEnc and tried to change a avi file but a error keeps comming up file not surrported i d/l easyvcd and did a test film works ok but now i cant encode a avi to mpeg in TMPGEnc
    thanx
    i know i`m a bit of a pain?
  6. hi
    sorted the templates out but everytime i use tmpgecnc i only get sound it will not give me pictures ?
  7. Do you have TMPGEnc with the VFP Plugin ? it might not be opening your AVI file correctly.
    Best Regards,
    Sefy Levy,
  8. found out how to change from avi to mpeg and how to
    BUT
    when the file in mpeg its to big to fit on 1 80min cd
    (d/l half a film changed it to mpeg tried to burn it TO BIG :o
    DO I HAVE TO COMPRESS IT SOMEHOW
    THANX
    WITH YOUR HELP I`M GETTING CLOSER
    Mar 2002
    chicago
    Convert
  10. If you are doing a standard Video-CD, then 80min movie = 800mb, and it WILL fit an 80min CDR media.
    Best Regards,
    Sefy Levy,
  11. great done it got it to work on sisters dvd well pleased
    INSTEAD OF HAVING THE MOVIE ON 2 CD IS THERE A WAY TO COMPRESS SO A 1.1/2 FILM WILL FIT ON A 80MB CD
    THANX
  12. Keep in mind if you paln to burn as SVCD or a XSVCD you better make sure the stand alone DVD player plays SVCD, about 90-95% of the players out there will play VCD or XVCD but less than 25% plays SVCD and you can forget about Sony, toshiba, panasonic or JVC playing SVCD's at all.
