    Nov 2007
    I'm here
    Hi everyone!
    Can you suggest a good way to remove chroma noise? The scenes are pretty static. I'm new to avisynth but I tried Cnr2. It did help a little but I have no idea how to tweak it for better results or should I even use it. I will upload a clip. The clip is rendered WITHOUT Cnr2. It's a progressive file.
    dehalo_alpha(rx=2, ry=2)
    TemporalDegrain(SAD1=200, SAD2=150, sigma=8)
    Cnr2("oxx",8,14,191,75,255,20,255,false)
    Sharpen(0.2)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1280, fheight=720)
    Sharpen(0.2)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1920, fheight=1080)
    Sharpen(0.2)
    Avisynth chroma filters are not the greatest.
    The Camcorder Color Denoise (CCD) filter for VirtualDub is better.
    Nov 2007
    I'm here
    Lordsmurf, thank you! This solved it!
  4. You should denoise before you upscale.
    Nov 2007
    I'm here
    Yes, I did that. Btw. Jagabo, I wanted to ask, why do upscaling in two phases? I read that it gives better results and if that is so, how do you calculate the first phase resolution? I mean, for example I want to upscale from 720x576 to 1280x720, so that means to first upscale to something in between of those two resolutions and then to the final resolution?
  6. When upscaling SD to 1080p I use nnedi3 to upscale about half way, sharpen a bit, then the other half, and sharpen a bit again. But for 720x576 to 960x720 I would just use one upscale.
