I'm working on some new features for FFQueue, but I've come to a problem I cannot solve. It involves using the trim and concat filters to cut away parts of a file (video/audio). For testing I use a transport stream from my HD-recorder and it contains a mix of movie and commercials - commercials are in stereo, movie is in 6ch surround. I can cut pieces of either commercials or movie without problems. But if the cuts overlap the switch between movie and commercial ffmpeg hurls out a large number of "Non-monotonous DTS..." errors and eventually aborts the encoding:
The test file is 2 minutes long, first minute are commercials, second minute is movie. This command works:Code:ffmpeg version N-74751-gb54e03c Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.3 (GCC) configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 59.100 / 56. 59.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.100 / 5. 40.100 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Input #0, mpegts, from 'test.ts': Duration: 00:02:00.66, start: 1.400000, bitrate: 9970 kb/s Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x101](dan): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 384 kb/s File 'test.mp4' already exists. Overwrite ? [y/N] [libx264 @ 0000000003e75020] using SAR=1/1 [libx264 @ 0000000003e75020] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000003e75020] profile High, level 3.1 [libx264 @ 0000000003e75020] 264 - core 148 r2597 e86f3a1 - H.264/MPEG-4 AVC codec - Copyleft 2003-2015 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=20.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00 Output #0, mp4, to 'test.mp4': Metadata: encoder : Lavf56.40.101 Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 25 fps, 12800 tbn, 25 tbc (default) Metadata: encoder : Lavc56.59.100 libx264 Stream #0:1: Audio: ac3 ([165][0][0][0] / 0x00A5), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: encoder : Lavc56.59.100 ac3 Stream mapping: Stream #0:0 (h264) -> scale Stream #0:1 (ac3) -> asplit concat -> Stream #0:0 (libx264) concat -> Stream #0:1 (ac3) Press [q] to stop, [?] for help frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 0 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate=N/A frame= 46 fps=7.0 q=0.0 size= 0kB time=00:00:02.20 bitrate= 0.2kbits/s frame= 72 fps= 10 q=25.0 size= 309kB time=00:00:03.25 bitrate= 776.2kbits/s frame= 102 fps= 13 q=25.0 size= 585kB time=00:00:04.44 bitrate=1079.2kbits/s frame= 125 fps= 15 q=25.0 size= 889kB time=00:00:04.98 bitrate=1460.8kbits/s frame= 125 fps= 15 q=25.0 size= 889kB time=00:00:04.98 bitrate=1460.8kbits/s frame= 145 fps= 16 q=25.0 size= 1083kB time=00:00:06.17 bitrate=1437.6kbits/s frame= 174 fps= 18 q=25.0 size= 1380kB time=00:00:07.25 bitrate=1557.3kbits/s frame= 212 fps= 21 q=25.0 size= 1614kB time=00:00:08.85 bitrate=1492.9kbits/s frame= 243 fps= 23 q=25.0 size= 1803kB time=00:00:10.10 bitrate=1461.7kbits/s Input stream #0:1 frame changed from rate:48000 fmt:fltp ch:2 chl:stereo to rate:48000 fmt:fltp ch:6 chl:5.1(side) [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505088, current: -256; changing to 505089. This may result in incorrect timestamps in the output file. ... [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505151, current: 96512; changing to 505152. This may result in incorrect timestamps in the output file. frame= 255 fps= 23 q=25.0 size= 1864kB time=00:00:10.55 bitrate=1446.4kbits/s dup=0 drop=50 [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505152, current: 98048; changing to 505153. This may result in incorrect timestamps in the output file. [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505153, current: 99584; changing to 505154. This may result in incorrect timestamps in the output file. ... [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505225, current: 210176; changing to 505226. This may result in incorrect timestamps in the output file. frame= 255 fps= 22 q=25.0 size= 1864kB time=00:00:10.55 bitrate=1446.2kbits/s dup=0 drop=119 frame= 255 fps= 21 q=25.0 size= 1864kB time=00:00:10.55 bitrate=1446.2kbits/s dup=0 drop=119 frame= 255 fps= 20 q=25.0 size= 1864kB time=00:00:10.55 bitrate=1446.2kbits/s dup=0 drop=119 [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505226, current: 211712; changing to 505227. This may result in incorrect timestamps in the output file. [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505227, current: 213248; changing to 505228. This may result in incorrect timestamps in the output file. ... [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505285, current: 302336; changing to 505286. This may result in incorrect timestamps in the output file. frame= 255 fps= 19 q=25.0 size= 1864kB time=00:00:10.55 bitrate=1446.0kbits/s dup=0 drop=157 [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505286, current: 303872; changing to 505287. This may result in incorrect timestamps in the output file. [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505287, current: 305408; changing to 505288. This may result in incorrect timestamps in the output file. ... [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505381, current: 449792; changing to 505382. This may result in incorrect timestamps in the output file. frame= 255 fps= 19 q=25.0 size= 1864kB time=00:00:10.56 bitrate=1445.7kbits/s dup=0 drop=244 frame= 255 fps= 18 q=25.0 size= 1864kB time=00:00:10.56 bitrate=1445.7kbits/s dup=0 drop=244 [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505382, current: 451328; changing to 505383. This may result in incorrect timestamps in the output file. [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505383, current: 452864; changing to 505384. This may result in incorrect timestamps in the output file. ... [mp4 @ 00000000049109e0] Non-monotonous DTS in output stream 0:1; previous: 505417, current: 505088; changing to 505418. This may result in incorrect timestamps in the output file. frame= 276 fps= 19 q=25.0 size= 1963kB time=00:00:10.97 bitrate=1466.0kbits/s dup=0 drop=253 frame= 309 fps= 20 q=25.0 size= 2094kB time=00:00:12.28 bitrate=1396.8kbits/s dup=0 drop=253 frame= 333 fps= 21 q=25.0 size= 2521kB time=00:00:13.24 bitrate=1559.5kbits/s dup=0 drop=253 frame= 356 fps= 22 q=25.0 size= 2763kB time=00:00:14.17 bitrate=1597.5kbits/s dup=0 drop=253 frame= 372 fps= 21 q=-1.0 Lsize= 3713kB time=00:00:14.80 bitrate=2055.1kbits/s dup=0 drop=253 video:3312kB audio:390kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.283109% [libx264 @ 0000000003e75020] frame I:5 Avg QP:15.45 size: 45853 [libx264 @ 0000000003e75020] frame P:127 Avg QP:19.91 size: 17251 [libx264 @ 0000000003e75020] frame B:240 Avg QP:21.92 size: 4044 [libx264 @ 0000000003e75020] consecutive B-frames: 7.5% 15.1% 12.9% 64.5% [libx264 @ 0000000003e75020] mb I I16..4: 14.6% 70.3% 15.1% [libx264 @ 0000000003e75020] mb P I16..4: 3.4% 10.4% 1.7% P16..4: 40.4% 15.0% 6.9% 0.0% 0.0% skip:22.3% [libx264 @ 0000000003e75020] mb B I16..4: 0.2% 0.5% 0.1% B16..8: 34.6% 3.2% 0.5% direct: 1.5% skip:59.6% L0:40.8% L1:55.2% BI: 4.1% [libx264 @ 0000000003e75020] 8x8 transform intra:67.3% inter:85.6% [libx264 @ 0000000003e75020] coded y,uvDC,uvAC intra: 54.5% 64.2% 29.2% inter: 15.1% 18.2% 0.9% [libx264 @ 0000000003e75020] i16 v,h,dc,p: 26% 46% 3% 25% [libx264 @ 0000000003e75020] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 18% 16% 5% 7% 9% 6% 9% 5% [libx264 @ 0000000003e75020] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 26% 11% 5% 7% 7% 5% 6% 3% [libx264 @ 0000000003e75020] i8c dc,h,v,p: 51% 25% 19% 6% [libx264 @ 0000000003e75020] Weighted P-Frames: Y:1.6% UV:1.6% [libx264 @ 0000000003e75020] ref P L0: 57.5% 11.9% 20.4% 10.2% 0.0% [libx264 @ 0000000003e75020] ref B L0: 86.0% 11.0% 3.0% [libx264 @ 0000000003e75020] ref B L1: 96.2% 3.8% [libx264 @ 0000000003e75020] kb/s:1822.88
This command works:Code:ffmpeg -i "test.ts" -map 0:0 -map 0:1 -filter_complex "[0:0]scale=1280:-1:flags=lanczos[FID1];[FID1]split=4[FID2][FID3][FID4][FID5];[FID2]trim=5:10,setpts=PTS-STARTPTS[FID6];[FID3]trim=15:20,setpts=PTS-STARTPTS[FID7];[FID4]trim=25:30,setpts=PTS-STARTPTS[FID8];[FID5]trim=35:40,setpts=PTS-STARTPTS[FID9];[FID6][FID7][FID8][FID9]concat=n=4:v=1:a=0;[0:1]asplit=4[FID10][FID11][FID12][FID13];[FID10]atrim=5:10,asetpts=PTS-STARTPTS[FID14];[FID11]atrim=15:20,asetpts=PTS-STARTPTS[FID15];[FID12]atrim=25:30,asetpts=PTS-STARTPTS[FID16];[FID13]atrim=35:40,asetpts=PTS-STARTPTS[FID17];[FID14][FID15][FID16][FID17]concat=n=4:v=0:a=1" -c:v libx264 -crf 20 -crf_max 35 -c:a ac3 -b:a 128k "test_ok_1.mp4"
This command fails:Code:ffmpeg -i "test.ts" -map 0:0 -map 0:1 -filter_complex "[0:0]scale=1280:-1:flags=lanczos[FID1];[FID1]split=4[FID2][FID3][FID4][FID5];[FID2]trim=65:70,setpts=PTS-STARTPTS[FID6];[FID3]trim=75:80,setpts=PTS-STARTPTS[FID7];[FID4]trim=85:90,setpts=PTS-STARTPTS[FID8];[FID5]trim=95:100,setpts=PTS-STARTPTS[FID9];[FID6][FID7][FID8][FID9]concat=n=4:v=1:a=0;[0:1]asplit=4[FID10][FID11][FID12][FID13];[FID10]atrim=65:70,asetpts=PTS-STARTPTS[FID14];[FID11]atrim=75:80,asetpts=PTS-STARTPTS[FID15];[FID12]atrim=85:90,asetpts=PTS-STARTPTS[FID16];[FID13]atrim=95:100,asetpts=PTS-STARTPTS[FID17];[FID14][FID15][FID16][FID17]concat=n=4:v=0:a=1" -c:v libx264 -crf 20 -crf_max 35 -c:a ac3 -b:a 128k "test_ok_2.mp4"
I've tried to fix the issue using any combination of "-copyts -copytb [0|1] -fflags +igndts+genpts (before and after -i)" and I've tried to insert "setpts=PTS-STARTPTS / asetpts=PTS-STARTPTS" at the beginning of the filter chain - but with no success.Code:ffmpeg -i "test.ts" -map 0:0 -map 0:1 -filter_complex "[0:0]scale=1280:-1:flags=lanczos[FID1];[FID1]split=4[FID2][FID3][FID4][FID5];[FID2]trim=45:50,setpts=PTS-STARTPTS[FID6];[FID3]trim=55:65,setpts=PTS-STARTPTS[FID7];[FID4]trim=75:80,setpts=PTS-STARTPTS[FID8];[FID5]trim=85:90,setpts=PTS-STARTPTS[FID9];[FID6][FID7][FID8][FID9]concat=n=4:v=1:a=0;[0:1]asplit=4[FID10][FID11][FID12][FID13];[FID10]atrim=45:50,asetpts=PTS-STARTPTS[FID14];[FID11]atrim=55:65,asetpts=PTS-STARTPTS[FID15];[FID12]atrim=75:80,asetpts=PTS-STARTPTS[FID16];[FID13]atrim=85:90,asetpts=PTS-STARTPTS[FID17];[FID14][FID15][FID16][FID17]concat=n=4:v=0:a=1" -c:v libx264 -crf 20 -crf_max 35 -c:a ac3 -b:a 128k "test_error.mp4"
Is this a bug in ffmpeg (using latest zeranoe build) or is there a magic trick to get about this?
Attachment contains test.ts, test.bat and ffmpeg_results.txt.
Results 1 to 10 of 10
I'm the developer behind FFQueue. My posts might reflect this! ;-)
Sorry, forgot attachment
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
afaik that isn't a bug, but more a missing feature, like most tools ffmpeg can't deal with files where the audio stream changes the channel count.commercials are in stereo, movie is in 6ch surround.
-> your best hope is to report this to the ffmpeg mailing list or bug tracker and hope that someone things this is worth spending time on.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thanks for your reply! I've tried to homogenize the audio with by resampling it with a "aresample=flags=res: och=2" filter before performing the trim & concat but it did no change. Omitting the trim & concat with command:
Produces no errors even though it processes two different audio streams. The output from ffmpeg suggests that the error is related to bad DTS (Decoder Time Stamps) and even if ffmpeg is told to ignore DTS and create new ones they cause problems. Weird..Code:ffmpeg.exe -ss 0:0:50 -i "test.ts" -map 0:0 -map 0:1 -filter_complex "[0:0]scale=1280:-1:flags=lanczos" -c:v libx264 -crf 20 -crf_max 35 -c:a ac3 -b:a 128k -t 0:0:20 "test.mp4"
Did you look at the resulting stream and it's channel count?
problem is that won't save the 5.1 signal, that would upmix the stereo channels of the 5.1 signal to 5.1
You're probably right. For now I'll just suggest that users do not perform trims that overlap different audio layouts because it seems to be the cause of the issue. Just dumb to encode an hour of movie and then have the whole thing wrecked by one frame of bad audio - there should be a opt out for this!
You could analyse your file beforehand to make sure you don't have such a file.Just dumb to encode an hour of movie and then have the whole thing wrecked by one frame of bad audio - there should be a opt out for this!
Also be warned it's always a bad idea to feed such streams to ffmpeg, since it might do unexpected things. (for example drop all but the two side speakers of a 5.1 stream, crash when your first few frames have mono audio and later you get 5.1 audio,....)
Just wondering: What to you use to set the cutting points? Are you aiming for frame accurate cutting?
Cu Selur
Ps.: Also cutting might cause problems if the video is vfr. (cutting normally doesn't crash, but the output can be async
Selur: As mentioned it's a new feature for FFQueue. There will be a GUI for setting the (time based) cuts and it works quite nice, actually! I've never had issues with ffmpeg and multichannel audio - but it seems ffmpeg can't handle changes in the audio stream layout. It almost seems like ffmpeg does not recognize the change in layout and continues to process the multichannel audio as if it was stereo. This obviously has to fail, lesson learned
Batch trim using FFMPEG
By taonas in forum EditingReplies: 4Last Post: 25th Feb 2021, 11:17 -
Interpretation of ffmpeg errors and repairing them?
By pxstein in forum Newbie / General discussionsReplies: 0Last Post: 15th Nov 2015, 04:04 -
ffmpeg "concat" question
By wallywalters in forum Video ConversionReplies: 3Last Post: 11th Jul 2015, 21:10 -
how to trim in FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2015, 11:04 -
H.264 TS -> MKV, AviSynth+DGAVCDecode+ffmpeg, trim recording + delay audio?
By Matchay in forum Video ConversionReplies: 3Last Post: 28th Jun 2012, 06:13
