First of all hi there everyone
Newbie here as a poster but i check this site out often
I have a NTSC recording which plays fine on my pal tv
tho it scrolls when i try and play it on the kids telly in the other room
id been trying to convert it to a vcd image using both Virtual Dub and
cineplayer DVR not only did i have the sound snyc problem (dealt with in another post) but my capture card picks up the picture strangly
the normal Pal captures ive made work a treat with this VHS but this tape is recieved thro the capture driver i have with the top of the image cut off and the bottom quarter filled with white noise![]()
the rest of the image looks great
has anyone else came across this problem and or any solutions????
any help greatly appriciated
thanx
Pete![]()
http://www.nexuslive.com
The UK's First Live Online Music Show -
You have a PAL VHS that can play ntsc?
tell me about it, same problem I have,
the reason beeing that 90% of the vcr makers
goes cheap and makes the NTSC signals
output as PAL-60 instead of true PAL.
What is the problem with that you may ask,
well its a hybrid format, kinda like ntsc but still PAL,
and most capturecard dont support this.
I managed to get it working
(without the distortion you mentioned)
in DScaler with my wintv PVR, because DScaler
supports PAL-60.
So for now my only way of capturing is
using DScaler, which sucks cus I cant capture to Mpeg
and cant use VDub. -
thanx for the reply fake sky
ill try that descaler out
petehttp://www.nexuslive.com
ok i got the image lookin sweet with dscaler
does anyone know of a good way to capture this image?
i dont have wintv
thanx again for the tip fakesky
i hadnt heard of PAL-60 before
so at least thats a lead
pete
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:11
