I'm trying to rip Mad Max Fury Road to fit on BD25. It'll fit with reencoding the video if I use ac3 audio problem The HD stream is TRUEHD/AC3 usually when I get this format I just use the core because it'll be at 640 and be done with it or there will be another english 5.1 track solely in ac3 by itself on a different stream. Well for some reason the core on the Mad Max (non 3D version, USA) the core is 384 and the extra stream is 448 and is descriptive audio. I want the main audio to be 640 ac3 so it'll fit on the BD25 and not be as low as 384 quality (the core).
Problem is no program will let me just convert the TRUEHD to ac3 640 it wont work. I either get the core at 384 or the huge 5GB TrueHD (which wont fit). Am i gonna have to convert TRUEHD/AC3 to DTS-MA somehow then back to 640 ac3 since no program so far will let me convert straight from TRUEHD to 640 w/o error or giving me 384 core instead?
Results 1 to 17 of 17
Are you talking about BD structure to BD structure?
You should be able to use EAC3to to extract the TrueHD without the core, then re-encode the core to 640kbps.
http://forum.doom9.org/showthread.php?t=172060
Then use TSMuxer to mux it all back into m2ts files to replace the original files. Re-encode from there.
It could be simpler or harder than that.
It should be possible, but it depends on what you're actually doing and what programs you're using.Last edited by ndjamena; 26th Dec 2015 at 10:29.
It errors out
The TrueHD i can get byitself but its 5GB and makes it too big for BD25. When I try to reencode the TRueHD to 640 it errors out or gives me the384 core.
ndjamena
The core is 384 naturally if I reencode it to 640 it'll still be 384 quality just bigger. Upsize your fries with that? More fries, but still the same crappy fries. -
I'm confused at to what the hell you're trying to do.
EAC3To can take a TrueHD stream without and core and create a new one for it, hence "re-encode the core".
I don't know if you need that because I don't know what you're doing or what you intend, but whatever the hell you're doing it can't be that hard. The hard part is giving you advice without knowing the actual goal. -
If it helps, Fury Road is an Atmos stream. If the programs you're using aren't up to date they'll crash while attempting to read it.
But updated programs should have been the first thing you tried. -
Simple Make TrueHD/AC3 (384kbps core) a 640kbps AC3 and I get an error: [09:50:44] Bitstream parsing for track 3 failed.
[09:50:45] Demuxing this track may still produce correct results - or not.
Thanks yes this helps a little.
The goal: Get BD50 Mad max Fury Road onto BD25 w/o reencoding video. If I keep TRUEHD it's too big for BD25 (w/o reencoding video) if I use ac3 it fits. Only way to do this is get rid of all audio/video streams except main video & audio in ac3 format. 384 core quality is too low for me, hence why I want 640 ac3.
ANYWAY THANKS ALL!
Anyway thanks guys, I already made a backup copy and just used 384 stream. This audio is different than the norm due to the 384 core and the fact it errors trying to do TrueHD (w/o core) to ac3. Prolly because it Atmos like ndjamena mentioned. Normally i use core cause its 640 or the TrueHD will convert to 640 w/o errors.Last edited by PatrickBatman; 26th Dec 2015 at 11:01.
Are you trying to keep the menus?
In what format do you need it?
Is it ok to simply point MakeMKV at the thing, because I know for a fact that using MakeMKV to re-encode the TrueHD into an MKV will work.
Then all you need to do is re-encode the video and shift the title into a blu ray format. -
Are you using eac3to to demux your stream before? Make sure you use latest eac3to. You do not mention what software you use.
eac3to.exe "F:\BDMV" 1) 3: "C:\demux\movie.THD+AC3"
1) would mean title 1 on BD and 3: track 3. I do not have that BD so your numbers might be different
or follow this to run commands in a sequence to know what you have on that BDLast edited by _Al_; 26th Dec 2015 at 11:46.
Mad Max Fury road with a 640kbps AC-3 stream. And yes, it would fit nicely onto a 25GB disc. The audio wasn't only larger than it needed to be because it was Atmos, being Atmos the TrueHD had 7.1 channels as well, which would be why the AC-3 core was given such a low bitrate.Code:
General Unique ID : 303732258775080719766595510512430209111 (0xE480B489A255FC27A22307343201D857) Complete name : D:\Mad Max Fury Road.mkv Format : Matroska Format version : Version 2 File size : 21.5 GiB Duration : 2h 0mn Overall bit rate mode : Variable Overall bit rate : 25.5 Mbps Movie name : Mad Max Fury Road Encoded date : UTC 2015-12-26 17:05:00 Writing application : MakeMKV v1.9.8 win(x64-release) Writing library : libmakemkv v1.9.8 (1.3.3/1.4.4) win(x64-release) Original source medium : Blu-ray Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 0mn Bit rate mode : Variable Bit rate : 2 488 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.050 Stream size : 20.9 GiB (97%) Language : English Default : No Forced : No Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 2h 0mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Stream size : 551 MiB (3%) Title : Surround 5.1 Language : English Default : Yes Forced : No Text ID : 3 ID in the original source medium : 4608 (0x1200) Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2h 0mn Bit rate : 1 760 bps Count of elements : 2334 Stream size : 6.57 MiB (0%) Language : English Default : No Forced : No Menu 00:00:00.000 : en:Chapter 01 00:10:42.433 : en:Chapter 02 00:19:06.353 : en:Chapter 03 00:30:12.310 : en:Chapter 04 00:42:55.573 : en:Chapter 05 00:49:33.303 : en:Chapter 06 00:59:54.966 : en:Chapter 07 01:13:02.503 : en:Chapter 08 01:22:08.924 : en:Chapter 09 01:30:02.480 : en:Chapter 10 01:40:39.825 : en:Chapter 11 01:49:12.546 : en:Chapter 12 01:53:06.279 : en:Chapter 13
Converted to a BD structure and written into an iso it comes out as 24,185,143,296 bytes in size.
Code:<outputSettings name="AC3-640" outputFormat="AC3"> <description lang="eng">Save as AC3 (640kbps)</description> <extraArgs>-b 640k</extraArgs> </outputSettings> <audioMixSettings name="Down51" outputChannelLayout="5.1"> <description lang="eng">Downmix to 5.1</description> </audioMixSettings> <trackSettings input="TRUEHD-multi"> <output outputSettingsName="copy" defaultSelection="$app_DefaultSelectionString,-sel:all"> </output> <output outputSettingsName="AC3-640" defaultSelection="$app_DefaultSelectionString" audioMix="Down51"> </output> </trackSettings> -
I use BD-Rebuilder (50.11), i would think Jdobbs would add an updated eac3to program thats builtin if needed but perhaps he hasn't I'd have to check. Well i just checked and could of sworn BD-Rebuilder used eac3to but i couldnt find the executable in the tools folder or any other folder for that matter. (i have only slept 4 hours though so maybe im missing it)
Ok im getting the latest 3.31 eac3to and as far as mkv i didnt think bluray standards would accept mkv on a BD25. I can make another better copy with my real copy. -
It doesn't.
The MKV contains h.264, ac-3 and pgs.
TSMuxer takes those tracks out of the MKV and puts it in an m2ts. They're the same codecs, they don't change because they've been in another container. An AC-3 track made by MakeMKV is the same as an AC-3 track made by the official Dolby encoder for a Blu Ray. All TSMuxer needs to do is take it out of the MKV and put it into an m2ts file and no program should be able to tell the difference.
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
What's the deal with Dolby TrueHD/AC3 Core?
By Starburst in forum Newbie / General discussionsReplies: 27Last Post: 17th Sep 2015, 10:36 -
Convert TrueHD from MKV, maintain original plus AC3
By rwttm001 in forum Video ConversionReplies: 5Last Post: 3rd Feb 2015, 14:59 -
Best tool to extract AC3 from an MP4, WHILE maintaining 384 bitrate?
By takearushfan in forum Newbie / General discussionsReplies: 2Last Post: 14th Nov 2013, 04:16 -
640 ac3 vs 448 ac3?
By hogger129 in forum AudioReplies: 13Last Post: 4th Jun 2013, 05:17
