Hello,
The question I have is simple. What difference is there between the output from DVDFab 9's MKV CRF 20 and the output from Handbrake on MKV CRF 20? For DVDFab, I have all "acceleration" shut off, it's only using Software encoding for all of it. I'm curious if it's doing anything differently than Handbrake would on the same settings? I am getting really quick encoding times in DVDFab too (<1hr). My hardware is an Intel i7-4790k "Devil's Canyon," 32GB of RAM, doing the encode onto the same HDD so as not to allow any latency/reading bottlenecks. Normally Handbrake would take me about 3-4x as much encoding time.
How come one is faster than the other? Is it because Handbrake has more "tuning" it's during the encode? If there was no difference, I should see approximately the same encoding time.
Thanks.
Results 1 to 11 of 11
Neither DVDFab nor Handbrake are "encoders". But both may use x264, so both will probably mean the same by "CRF 20". Still, the bit rate or quality level control is not the only parameter. It is well possible that one converter GUI uses x264 with a fast set of options, and another converter GUI prefers a slower set of options instead, maybe even does more filtering before even feeding the x264 encoder with video. If you can't grab the exact command line options set of both tools, you can't compare them. Not by comparing the CRF value alone.
Thanks for the information guys. So it seems like Handbrake/Vidcoder or BDRB is the proper way to go if I care about quality.
There is a 100 fold difference in encoding speed between x264's fastest (--preset ultrafast) and slowest (--preset placebo) presets. In addition, settings can be further customized for particular purposes. So if both are using x264 the difference in speed is mostly the settings that were used. MediaInfo shows the x264 Encoding Settings if they are in the file's metadata. So you can see for yourself what settings were used.
In general, with CRF encoding the slower the preset the smaller the file. Visual quality also increases with slower presets. Ie, there's no free lunch. -
You would be right if everything else was equal. But at the slower settings x264 uses more of the codecs features to both increase quality and reduce the bitrate. Ie, it's not just slow for the sake of being slow. It's spending more time looking for more compression and better quality.
My primary use of dfab , is to copy DVD to my hard drive backup
I have other software's for compressing encoding, if I wish to rip and store in mp4
I normally avoid mkv format for my own uses
Reposting some old x264 tests, crf vs settings
By poisondeathray in forum TestReplies: 3Last Post: 8th May 2015, 13:14 -
Re-encode using CRF lower than source's original CRF
By Anonymous54873 in forum Newbie / General discussionsReplies: 13Last Post: 13th Jan 2013, 20:40 -
x264 for Blu_ray: 2pass or crf?
By wiseant in forum Video ConversionReplies: 3Last Post: 2nd Jan 2012, 15:12 -
xvid equivalent to CRF from x264
By codemaster in forum DVD RippingReplies: 4Last Post: 22nd Sep 2011, 07:08 -
Source bitrates and x264 crf settings?
By orangeboy70 in forum Newbie / General discussionsReplies: 10Last Post: 2nd May 2011, 21:15
