hello star wars the Despecialized Edition basically removed the changes lucas made over time. my problem is trying to burn the 16gb .mkv to a blu ray. I have 25 gig disk and all but i cant find any info on software to use to burn the file so it can be recognised by a blu ray player and not just a file on the disk readable by like windows.
Results 1 to 12 of 12
Need more info,are you trying to backup your episode 4 star wars blu-ray as an authorized blu-ray?
no, I have the official blu ray disk and all. what im trying to do is burn a modified version that removes all the crap cgi and stuff to a blank blu ray disk. as i said its a .mkv and everything i have tried has resulted in the file being put unto the disk and not having it as like an actual disk
readable by a bluray player -
So, at best it needs to be remuxed, but likely it will have to be reconverted and certainly reauthored into proper BDMV formatting.
Scott -
Would something like this get it done? Assuming it's the same file I've got, here's the MediaInfo:
Code:General Format : Matroska Format version : Version 2 File size : 17.9 GiB Duration : 2h 1mn Overall bit rate : 21.0 Mbps Encoded date : UTC 2013-10-07 19:29:31 Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Muxing mode : Header stripping Codec ID : V_MPEG4/ISO/AVC Duration : 2h 1mn Bit rate mode : Variable Bit rate : 14.3 Mbps Nominal bit rate : 13.5 Mbps Maximum bit rate : 40.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.646 Stream size : 12.1 GiB (68%) Writing library : x264 core 125 r2208 d9d2288 Encoding settings : cabac=1 / ref=6 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=0 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=13500 / ratetol=1.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:0.80 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Header stripping Codec ID : A_DTS Duration : 2h 1mn Bit rate mode : Variable Bit rate : 1 576 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossless / Lossy Title : 5.1 DTS-HD-MA (1977 70mm six track mix) Language : English Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Header stripping Codec ID : A_DTS Duration : 2h 1mn Bit rate mode : Variable Bit rate : 685 Kbps / 640 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossless / Lossy Title : 2.0 DTS-HD-MA (1977 35mm stereo mix) Language : English Audio #3 ID : 4 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Header stripping Codec ID : A_DTS Duration : 2h 1mn Bit rate mode : Variable Bit rate : 429 Kbps / 384 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossless / Lossy Title : 1.0 DTS-HD-MA (1977 35mm mono mix) Language : English Audio #4 ID : 5 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 279 MiB (2%) Title : 2.0 Dolby Digital (1985 Laserdisc mix) Language : English Audio #5 ID : 6 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 279 MiB (2%) Title : 2.0 Dolby Digital (1993 Laserdisc mix) Language : English Audio #6 ID : 7 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1978 dub reconstruction) Language : German Audio #7 ID : 8 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1977 dub) Language : French Audio #8 ID : 9 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1977 Castilian dub) Language : Spanish Audio #9 ID : 10 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 83.7 MiB (0%) Title : 1.0 Dolby Digital (1980 Latino dub) Language : Spanish Audio #10 ID : 11 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 83.7 MiB (0%) Title : 1.0 Dolby Digital (1980s Brazilian dub) Language : Portuguese Audio #11 ID : 12 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1978 Dub) Language : Japanese Audio #12 ID : 13 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1977 dub) Language : Italian Audio #13 ID : 14 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1995 Voiceover) Language : Polish Audio #14 ID : 15 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1992 dub) Language : Czech Audio #15 ID : 16 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1984 dub) Language : Hungarian Audio #16 ID : 17 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (1993 LD Audio Commentary) Language : English Audio #17 ID : 18 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (2004 DVD Audio Commentary) Language : English Audio #18 ID : 19 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (2004 starwars.com Audio Commentary) Language : English Audio #19 ID : 20 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (2011 BD Archival Interviews Audio Commentary) Language : English Audio #20 ID : 21 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 279 MiB (2%) Title : 2.0 Dolby Digital (Isolated Score) Audio #21 ID : 22 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : Header stripping Codec ID : A_AC3 Duration : 2h 1mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 167 MiB (1%) Title : 2.0 Dolby Digital (Commentary For Visually Impaired) Language : English Menu 00:00:00.000 : en: 00:00:21.187 : en: 00:01:54.616 : en: 00:04:53.335 : en: 00:07:28.828 : en: 00:08:55.217 : en: 00:11:21.701 : en: 00:15:23.618 : en: 00:19:19.862 : en: 00:23:13.301 : en: 00:25:12.225 : en: 00:27:25.196 : en: 00:28:52.319 : en: 00:32:13.827 : en: 00:34:32.637 : en: 00:36:33.762 : en: 00:38:45.265 : en: 00:41:20.893 : en: 00:42:10.444 : en: 00:43:59.756 : en: 00:47:00.743 : en: 00:49:06.038 : en: 00:50:21.951 : en: 00:51:40.699 : en: 00:51:48.541 : en: 00:54:30.875 : en: 00:56:43.846 : en: 01:00:41.791 : en: 01:03:47.450 : en: 01:05:52.946 : en: 01:10:03.338 : en: 01:11:43.640 : en: 01:14:44.795 : en: 01:16:40.414 : en: 01:19:00.393 : en: 01:22:31.277 : en: 01:24:33.103 : en: 01:27:27.250 : en: 01:31:19.189 : en: 01:34:10.999 : en: 01:35:37.789 : en: 01:37:08.182 : en: 01:38:55.493 : en: 01:40:08.402 : en: 01:42:07.892 : en: 01:46:48.148 : en: 01:52:24.195 : en: 01:54:52.648 : en: 01:55:34.191 : en: 01:57:19.800 : en: -
No, max reference frames in Blu-ray is 4. Your video shows 6.
As already stated, puffpants will probably have to re-encode his video and author to Blu-ray format. tsMuxeR can certainly put things into Blu-ray format, but it doesn't check to see if anything actually meets the specifications for that format.Last edited by Kerry56; 24th Dec 2015 at 09:27.
no i have version 2.5 available on myspleen or thepiratebay or really any torrent site. what software would i need to convert it to a blu ray format and to burn it to a disk able to be played in any blu ray player?
If you don't need an elaborate menu, you could use BD Rebuilder for this. It will re-encode the movie to fit Blu-ray specifications, either 720p or 1080p, depending on what you want and what you are starting with. Look through the Settings.
To import the video into BD Rebuilder, assuming it isn't now in DVD or Blu-ray format, click on File-->Import-->Video Files. -
hello i tried BD Rebuilder and installed all the needed stuff but it wouldn't launch it gave me an error. any help with that software or and alts?
thanks
also i was able to transcode to an mp4 and its only about 4 gigs so its able to be put onto a dvd but when i did the quality went to crap but it could be played on a dvd player. is it possible to burn a 720p mp4 onto a dvd so it can be played in a dvd player and not like just a computer.
thanks -
No. DVD players output standard definition 720x480 NTSC or 720x576 PAL.
https://www.videohelp.com/dvd -
Could you be more specific on the error? I'd just be shooting in the dark without some hint.
You should use the versions of the helper programs that are available for download on the first page of the BD Rebuilder bug report page, found here. Read through that first page carefully.
You can also read the guide at MyCE.
Die Hard 25th Anniversary Edition 5 Disc Blu-ray $12.99 @ Best Buy
By louv68 in forum Off topicReplies: 1Last Post: 4th Jan 2014, 08:22 -
Problems ripping Aliens Special Edition Blu Ray
By miraks in forum Blu-ray RippingReplies: 4Last Post: 10th Jul 2013, 02:14 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 21:41 -
How to burn Blu ray in a similar way we can burn Dvd through Idvd
By rollingcanvas in forum MacReplies: 14Last Post: 16th Sep 2012, 22:26 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15
