A few questions that I'd like advice on. When I try to split videos with VideoReDo, it sometimes refuses an h264 file when it's mkv, but accepts the same file when it's mp4. Isn't that essentially "just" a different container?
Also MyMP4Box won't split frame accurate, but VideoReDo can? Does that mean that VideoReDo is quickly re-encoding the video? Because I don't really want that to happen but it isn't always obvious if it's doing that or not.
The story: I have a h264 encoded video and it's missing the end credits. I want to reconstruct those, but I'd prefer to insert that exactly between the right frames without re-encoding the rest.
Thanks. I know that many similar questions have been asked before; but some threads are several years old and new solutions might be around and such.
This is nøt å signåture.™
(Oh and there is something AFTER the end credits; otherwise it'd be easier of course.)
This is nøt å signåture.™ -
You don't have to insist on any particular software app, but you pretty much have to insist on the fact that for lossless, or "lossless", cuts and joins, you pretty much have two choices with a compressed format like H.264 (unlike other, say, intra-frame format like DV, etc).Originally Posted by Spiny Norman
1) Cut with a slight re-encoding of a few frames at the ends where the cuts (and joins) are. This is the only way you can be frame accurate to correct the video GOP in case you cut on a "frame in the group somewhere between key frames".
2) Cut without any re-encoding whatsoever. Unless this cut is exactly on a key frame, it will not be frame accurate.
Personally, I prefer the first option. It's only a few frames anyway. Furthermore, I don't care for them regardless, especially if I choose to cut/join there (and likely will apply a cross-fade if any transition is harsh.)I hate VHS. I always did. -
Yes, that seems good enough. I wasn't entirely up to date on how the key frames were handled but really it's more important to get frame accuracy, as you say. Thanks for the input.
Most simple Handbrake setting to convert MKV to H264 or Mp4
By joms in forum Video ConversionReplies: 65Last Post: 4th Jul 2015, 02:18 -
How do I convert/re-encode this huge mp4-file to mkv (h264)?
By Packan in forum Video ConversionReplies: 4Last Post: 21st Jun 2015, 15:50 -
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 08:38 -
MKV (X264) 4:3 to MP4 (H264) 16:9 with black borders
By itsonlyme in forum Video ConversionReplies: 2Last Post: 25th Oct 2011, 11:10 -
MP4 vs MKV for h264 content?? Based on HD PVR capures
By dynamis_dk in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2011, 11:22
