Trying to capture DV via Firewire passthrough to a Win7 Home Premium machine. Using a Sony Digital8 cam as the passthru box.
Trying to capture to a WD Green drive that I transferred over from an XP machine. Using WinDV to capture. WinDV shows that something is being captured but when I look at the drive, the file isn't there. If I look through WinDV using the set file location button the file is visible.
The other files that were put on the WD drive when it was in the XP machine are viewable and playable. Any idea what's happening?
Thanks.
windv probably does not have enough os permission to write file. make sure windv is NOT in c:/ program files of any kind. put it on a separate drive/folder like d:/ program files. or try right clicking the .exe/shortcut and running windv as admin.
XP doesn't have UAC like Win7 so permissions elevation can make a big difference.
Scott -
move it out of c: program files. make a directory call c: windv and put it in there. right click on the windv.exe file properties/compatibility and put a check mark in the box that says "run as administrator" click apply and then ok.
I run my copy of WinDV(under Win7) straight from the documents folder where it was saved to under XP.
In fact there are very few settings you can change - length of capture, capture folder, DV type.
Do you actually see the video when the "Capturing from DV Device" option is selected (left button). That is the one you use not the right button.
Cannot enter password to logon to Windows 7 Home Premium PC
By Brainiac in forum ComputerReplies: 17Last Post: 25th Jun 2015, 18:02 -
windows 7 home premium - driver installation problems .. [solved]
By vhelp in forum ComputerReplies: 17Last Post: 14th Nov 2014, 13:58 -
64bit vs 32bit apps under windows 7 home premium
By vhelp in forum ComputerReplies: 18Last Post: 26th Sep 2012, 18:57 -
Audio-Video Capture on Win7 Home Premium Aspire 5334 Laptop
By vaudkid in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2011, 00:26 -
[WIN7] 64 Home Premium & usb drive issues
By kenmo in forum ComputerReplies: 0Last Post: 3rd Jan 2011, 22:53
