About two or three months ago, the left-channel audio input cable slipped out of my capture card and I didn't notice until yesterday. That means quite a few recordings have audio coming out of just the right-hand speakers. The left channel is completely silent.
Is there a command line in FFMPEG that would, without having to re-encode the AAC audio, make right audio channel (0.1.1) sound come out of both left and right speakers?
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'recording.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf56.15.102
Duration: 00:24:42.74, start: 0.000000, bitrate: 10144 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 9951 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 185 kb/s (default)
Metadata:
handler_name : SoundHandler
I'm pretty sure you must reconvert the audio.
See https://trac.ffmpeg.org/wiki/AudioChannelManipulation
Maybe just right channel to left
Code:ffmpeg -i video.mp4 -c:v copy -c:a libfdk_aac -b:a 128k -map_channel 0.0.1 newvideo.mp4
I dont know if this is any help but I worked it out lastyear (dont ask me to explain I totally forget how I did it except I read the docs for ffmpeg!)
It is a .bat file for dos - you would need to adjust the path setting and codec.
Code:@echo off echo . echo path to ffmpeg is set echo enter .MKV file name containing single mono audio track and video track echo this will duplicate the audio track allowing winff to convert to ac3 audio set path=%PATH%;n:\dlprograms\ffmpeg\bin; ffmpeg -i %1 -f lavfi -i " amovie=%1:si=1 [a1]; amovie=%1:si=2 [a2]; [a1][a2] amerge" -c:a pcm_s16le -c:v copy dualmono.mkv echo . echo done echo.
FFMpeg and channel layout
By alexander121 in forum AudioReplies: 4Last Post: 22nd Mar 2015, 02:27 -
Advice on FFmpeg options to downmix DTS 5.1 audio into 2 channel?
By sienipulla in forum LinuxReplies: 0Last Post: 6th Sep 2014, 02:48 -
converting 6 channel audio to 2 channel & putting 2 streams in a container
By qorda in forum AudioReplies: 3Last Post: 14th Jan 2014, 02:43 -
Force left audio channel to both speakers
By encodingmonkey in forum EditingReplies: 15Last Post: 30th Nov 2012, 17:56 -
ffmpeg to capture audio from speakers?
By p3aul in forum AudioReplies: 3Last Post: 23rd Jun 2012, 17:35
