Hello,
I'm quite new to VCD thing so some help on a little question would be appreciated. In the manual of my Toshiba SD-110E it states that the player is not compatible with cd-r or cd-rw media however I burned one of my albums onto cd-r (Vivastar 700mb very cheap blue/green reflective side) and it runs perfectly through the DVD player. My questions is: Does this mean that VCD's burnt to cd-r y are also likely to play on my dvd player? Thanks very much
Hi
I have the same shitty player.
It will play writen music cd's cdr or cdrw.
It will not play vcd's .
I have been searching for a firmware update
but there dont seem to be one.
Sorry it wont play all cdr media,like cheap silvers.
It does play dvd backups perfect.
Hope this info helps.
dave king
AutoGK - Reencoding for ESS Compatiblity - MAINTAIN SAME FILE SIZE?
By GrayStrickland in forum Video ConversionReplies: 1Last Post: 27th Sep 2008, 12:59 -
Panasonic AG-HVx200 & Azden WMS-PRO compatiblity????
By tbrambo in forum AudioReplies: 3Last Post: 24th Jan 2008, 20:33
