Hope this is the right place for this since it is meant to be a sort of guide.
Recently, I needed to obtain the 'Artist' Metadata from an MP3 so I could add this to the filename when I created an MP4 from an MP3 and a JPG image. In order to do this, I needed to use EXIFTOOL to obtain the Metadata and set this into a variable to be used as part of a batch file. I used the following script as a batch file.
All mp3, batchfile.bat, ffmpeg, exiftool and you your image should be in the same folder or complete path names should be used and the quotes are very important for possible spaces in the file names or paths.
What this does is use exiftool to get the -Artist metadata and store it in a file called 'tmpfile.txt' then retrieve this and set as a variable called nb_artist. This is used to append the Artist name to the file name.Code:for %%a in ("*.mp3") do ( exiftool.exe -T -artist "%%a" > tmpfile.txt timeout 5 set /p nb_artist=< tmpFile.txt "ffmpeg.exe" -loop 1 -i SCREEN.jpg -i "%%a" -s 640x480 -shortest -c:v libx264 -tune stillimage -c:a copy -movflags faststart "%nb_artist% %%~na.mp4" )
The Timeout is necessary for DOS (CMD) to pause until the tmpfile.txt is written completely or it cannot be retrieved and set as a variable by the next step. It should be set long enough for your type of drive to completely write tmpfile.txt iscase you have slow drive like a USB drive. Timeout is included in Windows 7 and 8 Dos but not sure of Windows 10.
The resize -s was used here only because my image was not a valid x264 size (divisble by 2). It's not necessary otherwise.
This same obtaining information and then passing it to the rest of your batch file can be done with other multiple usage programs as well like obtaining Mediainfo information and using it in FFMpeg scripts.
Latest news? I think the Guides section is better?
We can keep/post all useful complex batch tips in this thread. -
I'll add more here then since I have a ton of them like embedding Created date/Time in images, set Meta creation date into MP4, run DGIndex against an MPG, and more unusual types.
Watch the quotes,single and double, around path names and variables containing path names!!!
Creating copies of images with created date embedded in image:
Code:for %%a in ("C:\Users\Bud\Desktop\imagefolder\*.jpg") do ( IF NOT EXIST "%%~dpaprocessed" MD "%%~dpaprocessed" "c:\path\exiftool" -CreateDate -FileCreateDate "%%a" > "tmpfile.txt" Timeout 1 FOR /F "tokens=1, 2, 3, 4, 5, 6, 7-15* delims=-: " %%b in (tmpfile.txt) DO ( "ffmpeg.exe" -i "%%a" -vf "format=yuv420p,drawtext=fontfile='c\:\\Windows\\fonts\\Arial.ttf':fontsize=24:text='Created %%e\:%%f\:%%g %%h\:%%i\:%%j': x=(w-(tw*1.05)): y=0: fontcolor=white@0.5: box=1: boxcolor=0x00000000@0.5" -y "%%~dpa\processed\%%~na.png" ) )Last edited by Budman1; 30th Dec 2015 at 15:03. Reason: Added Timeout for file write time/added direct path to Windows 7 Arial Font
This could get handy also, it tmpFile.txt does not exist or if tmpFile.txt is in use it waits 1 second. Advantage is, if there is everything all right no waiting needed ...
this could be handy in other situations, especially that "if file is in use - do something"Code::check if not exist "tmpFile.txt" timeout 1& goto :check ( type nul >> "tmpFile.txt" ) 2>nul || ( timeout 1& goto :check )
If we're doing this:
StringLength.bat for retrieving the length of a string, DigitCount.bat for retrieving info on whether a whole string is digits, whether the first character is a digit and how many characters are digits before a non-digit character occurs and PathExist.bat which retrieves whether a path exists and whether its a file or a directory.
StringLength.bat
DigitCount.batCode:@if not defined EMode (Set "EMode=OFF" & Set "Pause_On=Y") @ECHO %EMode% :strlen
SetLocal DisableDelayedExpansion CALL set "Test_String=%%%~2:"=_%%#" set "len=0" for %%P in (4096 2048 1024 512 256 128 64 32 16 8 4 2 1) do if defined Test_String CALL :strlen_loop %%P "%%Test_String:~%%P,1%%" EndLocal & set "%~1=%len%" & if defined Pause_On echo The string is %len% characters long. goto :eof :strlen_loop if %2=="" goto :eof set /a "len+=%1" CALL set "Test_String=%%Test_String:~%1%%" goto :eof
PathExist.batCode:@if not defined EMode (Set "EMode=OFF" & Set "Pause_On=Y") @ECHO %EMode% :DIGIT_COUNT
SetLocal DisableDelayedExpansion if "%~1"=="" goto :eof if not defined %~1 ( if Defined Pause_On ( echo The string is empty. pause ) EndLocal Set "Digit_Count=0" Set "String_Length=0" Set "Is_Digit=" Set "Is_Number=" goto :eof ) CALL Set "WORD=%%%~1:"=_%%" CALL StringLength LEN WORD Set "Digit_Count=0" for /l %%P in (0, 1, %LEN%) do ( Set "Is_Digit=" CALL Set "Test_Char=%%WORD:~%%~P, 1%%" for /l %%Q in (0, 1, 9) do if NOT Defined Is_Digit CALL :DIGIT_COUNT_LOOP ^%%Q if NOT Defined Is_Digit goto :DIGIT_COUNT_NEXT ) :DIGIT_COUNT_NEXT if Defined Pause_On echo There are %Digit_Count% digits. ( EndLocal Set "Digit_Count=%Digit_Count%" Set "String_Length=%LEN%" if %Digit_Count% GTR 0 ( if defined Pause_On ( if %Digit_Count% GTR 1 ( if %Digit_Count%==%LEN% ( echo The whole string is a number. ) else ( echo The string starts with %Digit_Count% digits. ) ) else ( echo The character is a digit. ) ) Set "Is_Digit=TRUE" if %Digit_Count%==%LEN% ( Set "Is_Number=TRUE" ) else ( Set "Is_Number=" ) ) else ( if Defined Pause_On echo The first character is NOT a digit. Set "Is_Digit=" Set "Is_Number=" ) ) goto :eof :DIGIT_COUNT_LOOP if "%Test_Char%"=="%~1" ( Set "Is_Digit=1" Set /a Digit_Count+=1 ) goto :eof
Code:@if not defined EMode (Set "EMode=OFF" & Set "Pause_On=Y") @ECHO %EMode% Set "DirExist=" Set "FileExist=" if NOT EXIST "%~f1" ( if NOT "%Pause_On%"=="" echo Path ^:%1^: Does Not Exist & pause Set "PathExist=" Set "IsSymLink=" goto :eof ) Set "PathExist=TRUE" Set "IsSymLink=%~a1" if "%IsSymLink:~8,1%"=="l" ( Set "IsSymLink=TRUE" if defined Pause_On echo Path ^:%1^: Is A Sybolic Link ) else ( Set "IsSymLink=" ) type NUL pushd "%~f1" 1>NUL 2>&1 if "%ERRORLEVEL%"=="0" ( popd if defined Pause_On echo Path ^:%1^: Is A Folder & pause Set "DirExist=TRUE" goto :eof ) if defined Pause_On echo Path ^:%1^: Is A File & pause Set "FileExist=TRUE"
A few more newly added ones:
Generate silent stereo audio:
Joining segments of different videos: (FLV CAN BE IMAGES CREATED WITH BLANK SOUND ABOVE)Code:ffmpeg -f lavfi -i "aevalsrc=0|0:d=5" output.wav
Code:a=directshowsource("C:\PathToVideo\img00001_IMG2VID_wAudio2.flv",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) b=directshowsource("C:\PathToVideo\img00003_IMG2VID_wAudio2.flv",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) c=directshowsource("C:\PathToVideo\clip.mp4",pixel_type="rgb24").lanczosResize(720,480).trim(1,120).ChangeFPS(30) d=directshowsource("C:\PathToVideo\img00005_IMG2VID_wAudio2.flv",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) aa = a ba = b ca = c da = d vid=aa+ba+ca+da newvid = vid.ChangeFPS(30)newvid
Transitions betwen images: (CAN MIX IMAGES AND VIDEO)
Code:loadplugin("c:\users\bud\desktop\transall.dll") a=imagereader("C:\Users\Bud\Desktop\img00001.jpg",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) b=imagereader("C:\Users\Bud\Desktop\img00003.jpg",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) c=directshowsource("C:\Users\Bud\Desktop\clip.mp4",audio=false,pixel_type="rgb24").lanczosResize(720,480).trim(1,120).ChangeFPS(30) d=imagereader("C:\Users\Bud\Desktop\img00005.jpg",pixel_type="rgb24").Spline36Resize(720,480).trim(1,120).ChangeFPS(30) aa = TransAccord(a,b,90,"hor",true,false) ba = TransBubbles(b, c, 90) next=d time=-5 ca = TransCrumple(c, next, 90,"fan",True) vid=aa+ba+ca newvid = vid.ChangeFPS(30)newvid -
I got bored, so this is my new PathExist.bat
It detects symbolic links, returns the path the link is pointing to, plus if it's pointing to yet another symbolic link or is in a symbolic link directory/directory junction it resolves those as well and returns the path to the ultimate target. AND it lets you set a prefix to the output variables so that if you need to check multiple paths you can do it without wiping all the previous values. If a symbolic link points to a path that doesn't exist or ultimately points back to itself the batch detects that an sets a brokenlink value. In the case of a directory symbolic link pointing to a file or vice versa the brokenlink value is set to MISMATCH.
for a command line like:
pathexist "C:\Users\User\Videos\TV Series (HD)\Eureka\Season 03\Eureka - 03x02 - What About Bob_.m4v" Source
Ultimate output looks something like this:
The missing unset values are Source.DirExist and Source.BrokenLink.Code:C:\Users\User>set Source Source.Aliases="C:\Users\User\Videos\TV Series (HD)\Eureka\Season 03\Eureka - 03x02 - What About Bob_.m4v" "F:\Videos\TV Series\Science Fiction\Eureka\Eureka - 03x02 - What About Bob_.m4v" "F:\Videos\iTunes\TV Shows\Eureka\Season 3\02 What About Bob_ (1080p HD).m4v" "F:\Music\iTunes\iTunes Media\TV Shows\Eureka\Season 3\02 What About Bob_ (1080p HD).m4v" Source.FileDate=04/04/2015 10:33 AM Source.FileExist=TRUE Source.FileName=C:\Users\User\Videos\TV Series (HD)\Eureka\Season 03\Eureka - 03x02 - What About Bob_.m4v Source.FileSize=1906139281 Source.IsSymLink=TRUE Source.PathExist=TRUE Source.PathLink=F:\Videos\TV Series\Science Fiction\Eureka\Eureka - 03x02 - What About Bob_.m4v Source.RootLink=F:\Music\iTunes\iTunes Media\TV Shows\Eureka\Season 3\02 What About Bob_ (1080p HD).m4v
Code:@if not defined EMode (Set "EMode=OFF" & Set "Pause_On=Y") @ECHO %EMode% SetLocal DisableDelayedExpansion :START Set "PathExistSet=%~2" if defined PathExistSet ( if "%PathExistSet:~-1%"=="." ( Set "PathExistSet=%PathExistSet%:" ) else ( Set "PathExistSet=%PathExistSet%.:" ) ) else ( Set "PathExistSet=:" ) Set "PathExist=" Set "DirExist=" Set "FileExist=" Set "IsSymLink=" Set "FileName=" Set "PathLink=" Set "BrokenLink=" Set "RootLink=" Set "AliasCount=0" if NOT EXIST "%~f1" ( if NOT "%Pause_On%"=="" echo Path ^:%1^: Does Not Exist goto :END ) Set "FileName=%~f1" Set "PathExist=TRUE" Set "Alias1=%~f1" Set "AliasCount=1" Set "Root=%~nx1" CALL :FindRoot "%~dp1" Set "PathLink=%Root%" Set "Check=%~a1" if "%Check:~0,1%"=="d" ( if defined Pause_On echo Path ^:%1^: Is A Folder Set "DirExist=TRUE" ) else ( if defined Pause_On echo Path ^:%1^: Is A File Set "FileExist=TRUE" ) if NOT "%Check:~8,1%"=="l" goto :NotSymLink Set "IsSymLink=TRUE" :IsSymLink CALL :GetPathLink "%PathLink%" if NOT defined PathLink goto :SymLinkInfo if NOT defined RootLink Set "RootLink=%PathLink%" if NOT defined FirstBroken ( if defined BrokenLink ( Set "FirstBroken=%BrokenLink%" ) else ( Set "FirstBroken=:" ) ) if "%FirstBroken%"==":" ( if defined BrokenLink ( Set "FirstBroken=%BrokenLink%" ) else ( Set "FirstBroken=:" ) ) Set "Check=" for /l %%i in (1,1,%AliasCount%) do CALL :CheckAlias "%%~i" "%PathLink%" if defined Check Set "BrokenLink=TRUE" Set /a AliasCount+=1 Set "Alias%AliasCount%=%PathLink%" for %%i in ("%PathLink%") do ( Set "Root=%%~nxi" CALL :FindRoot "%%~dpi" ) Set "PathLink=%Root%" for %%i in ("%PathLink%") do Set "Check=%%~ai" if defined Check if "%Check:~8,1%:"=="l:" if not defined BrokenLink goto :IsSymLink :SymLinkInfo if defined Pause_On ( echo Path ^:%1^: Is A Sybolic Link if defined PathLink echo Target: "%PathLink%" ) goto :end :NotSymLink Set "IsSymLink=" Set "RootLink=%PathLink%" :END if defined Pause_On if %AliasCount% GTR 0 ( echo Aliases: for /l %%i in (1,1,%AliasCount%) do CALL echo Alias%%i: "%%Alias%%i%%" ) if Defined Alias1 Set Alias1="%Alias1%" for /l %%i in (2,1,%AliasCount%) do call Set Alias1=%%Alias1%% "%%Alias%%i%%" if NOT defined Alias1 Set "Alias1=:" if NOT defined PathExist Set "PathExist=:" if NOT defined DirExist Set "DirExist=:" if NOT defined FileExist Set "FileExist=:" if NOT defined IsSymLink Set "IsSymLink=:" if NOT defined RootLink Set "RootLink=:" if NOT defined PathLink Set "PathLink=:" Set "FileSize=:" Set "FileDate=:" if NOT defined BrokenLink ( Set "BrokenLink=:" if defined PathLink for %%i in ("%PathLink%") do ( Set "FileSize=%%~zi" Set "FileDate=%%~ti" ) ) ( endlocal if "%PathExist%"==":" ( Set "%PathExistSet:~0,-1%PathExist=" Set "%PathExistSet:~0,-1%FileName=" ) else ( Set "%PathExistSet:~0,-1%PathExist=%PathExist%" Set "%PathExistSet:~0,-1%FileName=%FileName%" ) if "%DirExist%"==":" ( Set "%PathExistSet:~0,-1%DirExist=" ) else ( Set "%PathExistSet:~0,-1%DirExist=%DirExist%" ) if "%FileExist%"==":" ( Set "%PathExistSet:~0,-1%FileExist=" ) else ( Set "%PathExistSet:~0,-1%FileExist=%FileExist%" ) if "%IsSymLink%"==":" ( Set "%PathExistSet:~0,-1%IsSymLink=" ) else ( Set "%PathExistSet:~0,-1%IsSymLink=%IsSymLink%" ) if "%PathLink%"==":" ( Set "%PathExistSet:~0,-1%RootLink=" ) else ( Set "%PathExistSet:~0,-1%RootLink=%PathLink%" ) if "%RootLink%"==":" ( Set "%PathExistSet:~0,-1%PathLink=" ) else ( Set "%PathExistSet:~0,-1%PathLink=%RootLink%" ) if "%FileSize%"==":" ( Set "%PathExistSet:~0,-1%FileSize=" ) else ( Set "%PathExistSet:~0,-1%FileSize=%FileSize%" ) if "%FileDate%"==":" ( Set "%PathExistSet:~0,-1%FileDate=" ) else ( Set "%PathExistSet:~0,-1%FileDate=%FileDate%" ) if "%FirstBroken%"==":" ( Set "%PathExistSet:~0,-1%BrokenLink=" ) else ( Set "%PathExistSet:~0,-1%BrokenLink=%FirstBroken%" ) if %AliasCount% GTR 0 ( Set %PathExistSet:~0,-1%Aliases=%Alias1% ) else ( Set "%PathExistSet:~0,-1%Aliases=" ) ) if defined Pause_On pause goto :eof :CheckAlias CALL Set "Alias=%%Alias%~1%%" if "%Alias%"=="%~f2" Set "Check=TRUE" goto :eof :GetPathLink SetLocal DisableDelayedExpansion Set "PathName=%~nx1" CALL StringLength PathLen PathName Set "PathLink=" Set "BrokenLink=" for /f "tokens=4*" %%i in ('dir "%~f1" ^| FIND ""') do CALL :GetPathLink_File_Sub "%%j" if NOT defined BrokenLink Set "BrokenLink=:" if defined PathLink if defined DirExist Set "BrokenLink=MISMATCH" if defined PathLink for %%i in ("%PathLink%") do Set "attr=%%~ai" if defined PathLink if "%attr:~0,1%"=="d" Set "BrokenLink=MISMATCH" if defined PathLink ( EndLocal Set "PathLink=%PathLink%" if NOT "%BrokenLink%"==":" Set "BrokenLink=%BrokenLink%" goto :eof ) if "%BrokenLink%"==":" Set "BrokenLink=" for /f "tokens=4*" %%i in ('dir /A:D "%~f1*" ^| FINDSTR " "') do CALL :GetPathLink_File_Sub "%%j" if NOT defined BrokenLink Set "BrokenLink=:" if defined PathLink if defined FileExist Set "BrokenLink=MISMATCH" if defined PathLink for %%i in ("%PathLink%") do Set "attr=%%~ai" if defined PathLink if NOT "%attr:~0,1%"=="d" Set "BrokenLink=MISMATCH" echo %BrokenLink% if NOT defined PathLink Set "PathLink=:" ( EndLocal if NOT "%PathLink%"==":" Set "PathLink=%PathLink%" if NOT "%BrokenLink%"==":" Set "BrokenLink=%BrokenLink%" ) goto :eof :GetPathLink_File_Sub if DEFINED PathLink goto :eof Set "TempName=%~1" CALL Set "Temp=%%TempName:~0,%PathLen%%%" if NOT "%Temp%"=="%PathName%" goto :eof CALL Set "Temp=%%TempName:~%PathLen%%%" if NOT "%Temp:~0,2%"==" [" goto :eof Set "Temp=%Temp:~2,-1%" Set "Check=0" if NOT "%Temp:~1,1%"==":" Set /a Check+=1 if NOT "%Temp:~0,2%"=="\\" Set /a Check+=1 if %Check% EQU 2 goto :eof Set "PathLink=%Temp%" if NOT EXIST "%PathLink%" ( Set "BrokenLink=TRUE" ) else ( Set "BrokenLink=" ) goto :eof :FindRoot Set "CheckPath=%~f1" :TrimSlash if "%CheckPath:~-1%"=="\" Set "CheckPath=%CheckPath:~0,-1%" & goto :TrimSlash if "%CheckPath:~-1%"=="/" Set "CheckPath=%CheckPath:~0,-1%" & goto :TrimSlash for /d %%h in ("%CheckPath%") do if "%%~dh"=="%CheckPath%" ( Set "Root=%%~dh\%Root%" goto :eof ) for /d %%h in ("%CheckPath%") do Set "attr=%%~ah" if NOT "%attr:~8,1%"=="l" ( for /d %%h in ("%CheckPath%") do ( Set "Root=%%~nxh\%Root%" CALL :FindRoot "%%~dph" ) goto :eof ) for /d %%h in ("%CheckPath%") do Set "PathName=%%~nxh" CALL StringLength PathLen PathName Set "PathLink=" for /f "tokens=4*" %%i in ('dir /A:D "%CheckPath%*" ^| FINDSTR " "') do CALL :GetPathLink_File_Sub "%%j" if defined BrokenLink ( echo ERROR: Illogical Broken Symbolic Link ERROR echo %~f1 pause goto :eof ) if not defined PathLink ( echo ERROR: Illogical Missing Symbolic Link ERROR echo %~f1 pause goto :eof ) Set /a AliasCount+=1 Set "Alias%AliasCount%=%PathLink%\%root%" CALL :FindRoot "%PathLink%" goto :eof Last edited by ndjamena; 1st Jan 2017 at 19:28.
This batch will prompt for UAC elevation.
Name it Elevate.bat and put this at the top of any batch file that needs to be run elevated:
CALL Elevate.bat "%~f0" %*
I use it to enable the creation of Symbolic Links using MKLINK. I use Symbolic links to manage all my video metadata and command line executables.
I stole most of the code from StackOverflow but I altered it so that it could be its own batch that could be called from any other batch.
Code:@if not defined EMode (Set "EMode=OFF" & Set "Pause_On=") @ECHO %EMode% CLS :init setlocal DisableDelayedExpansion set "batchPath=%~f0" set "vbsGetPrivileges=%Temp%\OEgetPriv_%~n1.vbs" setlocal EnableDelayedExpansion :checkPrivileges NET FILE 1>NUL 2>NUL if '%errorlevel%' == '0' ( goto gotPrivileges ) else ( goto getPrivileges ) :getPrivileges ECHO. ECHO ************************************** ECHO Invoking UAC for Privilege Escalation ECHO ************************************** ( ECHO Set UAC = CreateObject^("Shell.Application"^) ECHO args = "/c " ^& Chr^(34^) ^& Chr^(34^) ^& "%batchPath%" ^& Chr^(34^) ^& " " ECHO For Each strArg in WScript.Arguments ECHO args = args ^& Chr^(34^) ^& strArg ^& Chr^(34^) ^& " " ECHO Next ECHO args = args ^& " " ^& Chr^(34^) ^& "ELEV" ^& Chr^(34^) ^& Chr^(34^) ECHO UAC.ShellExecute "cmd", args, , "runas", ^1 )>"%vbsGetPrivileges%" "%SystemRoot%\System32\WScript.exe" "%vbsGetPrivileges%" %* exit :gotPrivileges Set "Arguments=" :GetArguments if "%~1"=="ELEV" if "%~2"=="" ( del "%vbsGetPrivileges%" 1>nul 2>nul cd /d "%BatchFolder:~0,-1%" endlocal endlocal CALL %Arguments% goto :eof ) if defined Arguments ( Set Arguments=%Arguments% ) else ( Set "vbsGetPrivileges=%Temp%\OEgetPriv_%~n1.vbs" Set "BatchFolder=%~dp1" ) Set Arguments=%Arguments%"%~1" shift if NOT "%~1"=="" goto :GetArguments endlocal endlocalLast edited by ndjamena; 8th Jan 2017 at 08:19.
DOS batch: looking for user input (Y/N) with a timeout
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 16th Nov 2014, 06:22 -
DOS batch command variable
By sambat in forum ProgrammingReplies: 6Last Post: 24th Sep 2014, 13:14 -
using IF in a dos batch procedure
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2014, 00:18 -
Simple but Complex. Batch sort video files
By hbelouf in forum Video ConversionReplies: 2Last Post: 1st Aug 2012, 18:00 -
DOS: redirect the output of an executable into a batch variable?
By RogerTango in forum ProgrammingReplies: 2Last Post: 7th May 2012, 08:36
