I have vob file I have downloaded from internet. It is a THX-demo. How can I play this file on my standalone dvd-player?Can I just burn the file to a cdr and then play it on dv-444 or what must I do to get this file to work on my standalone dvd-player.
you need to reauthor it and burn it on a dvdr(w)/dvd+r(w). if you author and burn on a cdr(w) you have created a minidvd/cdvd www.vcdhelp.com/minidvd.htm and most players do not support that.
Hi
First:
How big is the files?
Second:
If you have a DVDburner i gues u can burn them on one CDr
Third:
Encode it to SVCD and burn it on a CDr (That for sure will work, i have the same player.).
Fourth:
Try to run this command in MSDos format c: /q.
Fifth:
Forget the fourth it was just a JOKE
DVD will play in PIONEER Standalone but NOT Recognise in...........
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2009, 23:14 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to DVD - Doesn't play in Standalone
By simonsickboy in forum DVD RippingReplies: 9Last Post: 15th Feb 2008, 10:12 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 08:52 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
