I just finished a 2-pass encode of a 90 minute video using HCenc and it took nearly 7 hours. My main complaint is it only averaged about 13% CPU usage on my machine. Is there some sort of multi-thread option that I am missing? Thanks.
Results 1 to 13 of 13
From the documentation of v0.28 (misc\HC028.pdf):
HCenc 028 is a multi-threaded application, it's also possible to run multiple instances of HCenc. -
There is an SMP option, but like most MPEG 2 encoders, it's not well multithreaded. Its speed doesn't increase much beyond two threads.
I deleted my previous comment about QTGMC as you are not using it here.
This topic finally got me to test out HCenc, and got to say it's pretty great. I have a 6 core AMD FX-6300 and I seem to be getting ~65% CPU usage across all the cores during Pass 1, and ~65% CPU usage during Pass 2. Using the best profile.
I used a x264 SD video for this test and so only had avisynth resize horizontally.Last edited by KarMa; 21st Dec 2015 at 13:19.
Not a problem.
No.
QTGMC() definitely needs AviSynth MT. But it sounds like you're not using it here.
HCEnc is the big problem. It can barely use two threads to their fullest. Don't expect it to use more than about 25 percent of an eight thread CPU under the best of circumstances. -
Sorry for the confusion. No, I am not using QTGMC for this script. I just mentioned it because I have successfully sped up Avisynth in the past using QTGMC, and I currently run the Avisynth MT dll because of QTGMC. So I was wondering if maybe I needed to insert some MT lines into my script.
Thanks jagabo for the clarification. That is too bad to hear though.
I am going to start calling you Special Sauce. I am sooper jealous. What is your secret other than that you have an Athlon? Also, are you using the HCenc GUI of CLI? -
My script:
Code:video1 = AVISource("E:\1.avi", audio=false).AssumeFPS(30000,1001).ConvertToYV12(interlaced=false, matrix="rec601") video2 = AVISource("E:\2.avi", audio=false).AssumeFPS(30000,1001).ConvertToYV12(interlaced=false, matrix="rec601") ... video12 = AVISource("E:\12.avi", audio=false).AssumeFPS(30000,1001).ConvertToYV12(interlaced=false, matrix="rec601") video1 ++ video2 ++ ... ++ video12 Sharpen(0.5, 0) BlackmanResize(704, 480, taps=4) Blur(0, 0.7, false).Sharpen(0, 0.4, false)
EDIT: I am not doing any NR, I did all all my post-production in AE before writing out the lossless intermediates. The only thing I am trying to do is get them into a DVD compliant resolution before encoding. -
What's the resolution of the source AVI files? The 1920x1080p30 videos you mentioned in another thread?
I just tried a 1920x1080p30 lagarith video on a hard drive with your script. The file was about 8 minutes long, 60 GB (big enough that Windows couldn't cache it all in memory). Hcgui encoded it at about 22 frames per second, consuming about 18 percent of the CPU (as reported by TaskManager) on my i5 2500K. It didn't matter much whether I used SMP in hcenc or AviSynth. Reading the lagarith avi was the bottleneck.
Doing the same with a 1920x1080 MPEG 2 source of the same length (a 1 GB file), with SMP, encoded about 3x faster.
Fun with HCenc
By SameSelf in forum Video ConversionReplies: 11Last Post: 18th Jan 2015, 15:00 -
Capability of Sapphire HD 7870
By GLE3 in forum ComputerReplies: 3Last Post: 21st Feb 2014, 13:21 -
HCenc versions
By davexnet in forum FeedbackReplies: 2Last Post: 7th Feb 2014, 17:35 -
HCbatchGUI - (batch processor for HCenc and Aften). Development Thread.
By freebird73717 in forum ProgrammingReplies: 253Last Post: 28th Nov 2012, 17:07 -
HCenc and PanScan
By Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 17:35
