  1. Recently I was given a video file in mpg2 quality and I rather suspect it's a youtube download "upgraded" to mpg2.
    Is there any way to detect this? I mean other than purely visibly, does it leave any telltale traces? Any useful answers will be very much appreciated.
    One more thing, it was pillarboxed AND set to 4:3 so that youtube displays it doubly pillarboxed (taller than it is wide). The pillarboxing has been cut off completely in the mpg2, but in itself that doesn't prove anything since that could have been done to any source format.
    I extracted the following data:
    File Size (in bytes) ............................: 1,473,114,112 bytes
    Runtime ............................................: 23:24.960
    Video Codec ...................................: MPEG-2
    Frame Size ......................................: 720x576 (AR: 1.333)
    FPS .................................................: 25.000
    Video Bitrate ...................................: 6693 kb/s
    Bits per Pixel ...................................: 0.646 bpp
    B-VOP, N-VOP, QPel, GMC.............: [], [], [], []
    Audio Codec ...................................: DVD_LPCM_AUDIO
    Sample Rate ...................................: Hz
    Audio Bitrate ...................................: kb/s [ channel(s)]
    No. of audio streams .......................: 1
    Format : MPEG-PS
    File size : 1.37 GiB
    Duration : 23mn 24s
    Overall bit rate : 8 388 Kbps
    Writing library : (dvd5: Oct 27 2015)
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Duration : 23mn 24s
    Bit rate mode : Variable
    Bit rate : 6 685 Kbps
    Maximum bit rate : 9 800 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.645
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    GOP, Open/Closed of first frame : Closed
    Stream size : 1.09 GiB (80%)
    Audio
    ID : 189 (0xBD)-160 (0xA0)
    Format : PCM
    Format settings, Endianness : Big
    Format settings, Sign : Signed
    Muxing mode : DVD-Video
    Duration : 23mn 24s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 257 MiB (18%)
    This is nøt å signåture.™
  2. Originally Posted by Spiny Norman View Post
    There won't be anything from mediainfo that can tell you. Only by visual examination and comparison , and even that isn't necessarily definitive. Only if the YT version had something specific, some specific artifact or marking could you be fairly certain
  3. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Yes, MediaInfo will tell you nothing regarding the file's lineage. It will only take the file at face value, as an MPEG-2 file. Period.
    Only by visual examination can you tell (if so).
    Do you see the suspected video on YouTube?
    If so, some things you can try.
    Look for certain clues, particularly an artifact, as poisondeathray mentioned. As an example, plagerism cases in court were won by proving a mistake from the original was repeated in the copy.
    Also, MPEG-2 has its own more-or-less unique set of encoding artifacts, particularly at lower bitrates, so look for certain macroblocking, DCT noise, mosquito noise, etc, ON TOP of what's on the YouTube version.
    If you don't know what those artifacts are, you can download the video from YouTube, and encode it with an MPEG-2 encoder to the same bitrate, and cropping, and inspect it, and see how close it looks to the file you got.
    And if it was resized, allegedly from a YT file, you can see such resizing artifacts as well.
    I hate VHS. I always did.
  4. Thanks, that's what I was afraid of. The problem is that artefacts are not that frequent anymore now that bitrate and codecs are really good. I'll have to comb through a bit.
