Results 1 to 9 of 9
  1. Member loa909's Avatar
    Mar 2007
    I am having this problem with a movie I burnt to a dvd. when playing it on a home dvd player its freezing for about 3 seconds at a time, now its just over halfway through and its frozen and wont continue
    I converted the movie with ConvertXtoDVD as it was a .mkv file then i burnt it to a DVD-R Verbatim ones so should be best using Ashampoo I have had this happen a lot with movies lately so annoying as cant understand why
    can anyone recommend a better convert program and burning program, as I cant understand why they do that
  2. A lot of folks around here (me included) are fans of AVS2DVD for authoring and imgburn for burning.
  3. Member loa909's Avatar
    Mar 2007
    ok mate thanks i will give those a try
    I have just added movie to avstodvd now it says this what do I select
Name:	movie error.jpg
  4. Mod Neophyte redwudz's Avatar
    USA
    I would click 'Yes', assuming that NTSC playback isn't a problem for you. Converting NTSC to PAL sometimes yields a quality loss.
  5. Member loa909's Avatar
    Mar 2007
    I am in the UK so is NTSC playback fine then
    anyone knows if NTSC is ok for the UK as i thought PAL was best to use in the UK
    Jan 2007
    pal is UK standard
    but your dvd player & TV might be NTSC compatible
    i can play 25 fps PAL on my USA system, but some of my friends with $29 walmart specials can not
  7. Member loa909's Avatar
    Mar 2007
    Originally Posted by theewizard View Post
    pal is UK standard
    Ok but now i have tried another movie and it says these 3 errors. the movie is a .mkv
    Jan 2007
    You obviously have problems decoding mkv files
    Do these files actually play on your pc, have you watched these movies all the way thru,?
    I suspect they is something wrong with these files
    Have you used media info, on these files, do that and post the results here as text in your post
  9. Member loa909's Avatar
    Mar 2007
    Hi sorry for late reply I have now deleted the movies, as they kept sticking. but next time will use media info
