What is the best x265 video converter??
What do you mean? Do you understand the differences between x265 (one encoder software), HEVC (the specification for the resulting video format), and "converter" (a user interface handling the whole sequence from a source format to a target format) at all?
The best for you is what you can handle. We don't know your preferences. Therefore, never ask "what's the best" without enough constraints to understand in which direction your optimum is, and what your desired source and target formats are exactly (remember, x265 is the software used to encode, not the format to be encoded to – that would be HEVC, probably in a container like MP4 or MKV).
Regarding output format and quality, all converters using the same x265 encoder are equal; the only difference may be their user interface targeting at different kinds of users, depending on their knowledge of video conversion details.
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 07:14 -
Simple multi video format test - x264, x265 and webm
By ricardouk in forum Video ConversionReplies: 0Last Post: 1st Oct 2015, 10:37 -
Cutting of x265 video file
By jswl.dty in forum EditingReplies: 17Last Post: 24th Jan 2014, 11:49 -
Wondershare Video Converter Ultimate vs WonderFox HD Video Converter Factor
By zzzk in forum Video ConversionReplies: 1Last Post: 3rd Jan 2014, 16:25 -
The fascinating quality of x265!1080p video with fast movements in 1300kb/
By Stears555 in forum Video ConversionReplies: 76Last Post: 12th Dec 2013, 08:00
