Would these bitrates be ok for 720p and 1080p
720p 5500kpbs to 6500kpbs
1080p 8500kbps to 10000kpbs
What should be the bitrate for 4K so the video will have good quality and keep the videos under 5gb
All these videos will be MP4
Completely depends on content, codecs/settings used, and the quality you want.
Usually, but for the x264 encoder it's better to use CRF encoding unless you need the same bitrate all the time for some reason. It's better to have the same quality each time instead of the same bitrate. CRF18 is roughly where the encoder is considered to be "transparent". Lower CRF values = higher quality and larger file sizes. The bitrate will vary for each encode, depending on how hard the video is to compress (ie noisy video will require a higher bitrate than clean video).
The question doesn't really make sense because bitrate x duration = file size, so the bitrate required for quality will depend on how hard the video is to compress while the bitrate required for a certain file size will depend on how long that piece of string is.
VBF Buffer Size And Maximum Bitrate For 480P/720P/1080P
By anime12345 in forum Video ConversionReplies: 17Last Post: 7th Oct 2015, 04:18 -
What bitrate should be used for 720p and 1080p mp4 files?
By brusno in forum Video ConversionReplies: 6Last Post: 23rd Feb 2013, 07:52 -
converted 1080p 59fps to 720p & Mbps drops big time
By jbitakis in forum Video ConversionReplies: 4Last Post: 24th Nov 2012, 23:10 -
Extract DTS-HD MA & 1080p to 720p
By thinredline in forum Blu-ray RippingReplies: 14Last Post: 9th Sep 2012, 18:08 -
Bitrate for true 1080p or 720p?
By smackyourfupa in forum Blu-ray RippingReplies: 24Last Post: 19th Mar 2011, 11:29
