I'm putting together a DVD in Premiere: a montage of multiple song clips, with simple transitions inbetween.
Trouble is, some of the clips are 720 wide, others are 704 wide.
I don't think there's any way to do this is there, without scaling one set of clips and losing quality?
Results 1 to 14 of 14
Or you can put all the 704 clips in one title set, and all the 720 clips in another.
I think you misunderstood pandy. 704->720 using pad does change the size from 704->720, but it is not "resizing" in the usual sense of resampling.
But NO it will NOT squash the image, unless the hardware is doing something off (which you can't completely guard against).
Scott -
Is that the proper term, "padding"? All these years and I never knew that. I've heard of pads in music though.
Actually, the padding is the result of flattening to the background. A reverse crop would result in a resize.
Its a composite between two layers.
Not to mince hairs, but the devil IS in the details. hahaha.Last edited by budwzr; 19th Dec 2015 at 19:59.
@budwzr, it doesn't have to be a composite, nor multiple layers. Think of this analogy in the photo world: Change Canvas Size in Photoshop. Can easily work with just one element and one layer, but it can pad (aka apply "padding" or "cushioning" to) the surrounding edge.
But it doesn't affect in the least the quality of the original active picture area, nor does it change the active area's Aspect Ratio (though it might change the overall resolution and AR, and that might affect how a decoder/player treats it and thus the active picture area).
Scott -
@Scott, yeah, yeah, no disagreement.
The tools in PS don't all translate into video editing. I don't think the NLE's can handle elements without a layer.
EDIT: Oh, I get it. Padding is Adobe nomenclature?Last edited by budwzr; 19th Dec 2015 at 23:19.
When I said padding's the opposite of cropping, I meant theoretically. I wasn't talking about software-specific functions.
Advice for combining clips of diffrint specs
By drunkelf34 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2014, 04:02 -
scaling question
By hoodleehoo in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2013, 07:29 -
ffmpeg automatic scaling possible?
By richiedood in forum Video ConversionReplies: 14Last Post: 2nd Jul 2011, 09:52 -
Combining clips of varying bitrates, but maintaining quality?
By Grunberg in forum EditingReplies: 7Last Post: 22nd Jun 2011, 21:38 -
Trying to edit various source clips, different resolutions in Sony vegas
By sevenofone in forum EditingReplies: 4Last Post: 30th Jan 2011, 17:29
