Hello,
I'm new and I'm trying to burn an snl compilation. The message is the Divx/xviD codec is not supported. The other message is width (640) not compliant. The avi files vary in quality from 480 up to 1280. I'm able to customize the menus but the transcode process is only thing that is still red. Any suggestions?
Are you trying to make a Blu Ray spec disk that can be played on a standalone Blu Ray player or are you just burning a bunch of files onto disk for storage? What software are you using?
I'm using MultiAVCHD 4.1. I would like to ideally play this disc on any standalone Blu-ray player.
Burning avi/mkv/whatever files as a BD-R/RE data disk for my Blu-Ray player
By Braindrain in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Jul 2014, 07:13 -
Converting Avi Files To Blu Ray
By JustSome1 in forum Video ConversionReplies: 4Last Post: 1st Jun 2014, 04:17 -
Reduce Blu Ray FOLDER/FILES to record a 25 GB Blu Ray
By xeikon in forum Video ConversionReplies: 4Last Post: 18th Mar 2014, 14:20 -
Do these blu ray products rip blu ray movie files on to your computer?
By missyxxmischa in forum Authoring (Blu-ray)Replies: 6Last Post: 11th Nov 2012, 18:01 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15
