Is 1080i (if native not available) most ideal setting, when watching both; SD and HD channels on 1080p TV? Also is it better let the TV handle (upscaling and) deinterlacing, rather that set top- or cable box? In this case TV is Sony Bravia 46".
Referring to the question above; is 1080i better setting for set top box than 1080p. I mean, if it's 1080p, then deinterlacing is processed by the box, rather than TV.
If native resolution is not available, try 720p and 1080i to find out which you prefer to handle a mix of SD and HD channels. A newer TVs from one of the major consumer electronics manufacturers can usually upscale and deinterlace to 1080p more competently than a set-top box, but once again you should try both options with the channels that you watch most often and see which looks better to you.
Capture 1080p from Freeview Box from HDMI to PC via USB.
By Wam7 in forum Capturing and VCRReplies: 1Last Post: 22nd Aug 2013, 00:26 -
Is there a way to control a TV set top box over a LAN?
By True Colors in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2011, 13:00 -
Any way to record from my Sky HD box? through AV or HDMI?
By gretaro in forum DVB / IPTVReplies: 2Last Post: 9th Apr 2011, 15:08 -
Searching for DVD Box set
By Arok01 in forum ComputerReplies: 5Last Post: 20th Mar 2011, 12:26 -
live video streaming to set box Help
By alexandros27 in forum Video Streaming DownloadingReplies: 0Last Post: 9th Feb 2011, 03:28
