Hello,
I'm seeking for the best converter Video low voice to MP3 higher. Not FormatFactory please.
	Do you just want to increase the volume? If so, open the MP3 with MP3DirectCut and use the Edit/Normalise menu. It'll scan the file and tell you how much you can increase the volume so the peaks will be at maximum level. You can adjust the volume and save it as a new MP3 without re-encoding.
 If the MP3 is in a video container (AVI, MKV etc), you'll have to extract it first, the remux it after adjusting the volume. It's a bit hard to give instructions without knowing more details.
  Recommended bit and sample rates for very high,high,medium and low qualityBy alexander121 in forum AudioReplies: 0Last Post: 16th Jun 2015, 12:38
  Looking for Video Converter using low CPUBy famousredhead in forum Video Streaming DownloadingReplies: 12Last Post: 23rd Mar 2015, 12:31
  High bitrate/low res VS Low bitrate/high resBy burakyazan in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2014, 08:21
  How to slow down VHS playback slightly - voice is too highBy trombonecharlie in forum Video ConversionReplies: 6Last Post: 27th Sep 2013, 18:29
  Cap high then encode low or cap low first from hd source?By yoda313 in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2013, 20:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
