    Dec 2015
    Australia
    Hi, I just shot a short film with a Sony F35, and all the video files are in dpx files of each frame, I wanted to know how I can import the actual video? I'm using premiere pro 2015 with windows 8.
    Oct 2005
    666th portal
    are you asking how to import an image set? or when trying to import dpx files they aren't recognized?
    Dec 2015
    Australia
    The dpx files aren't recognized.... ? I can copy it from After Effects to Premiere but then it imports it at around 7000 individual frames, rather than the clip itself.
  4. Importing image sequence to clip in Premiere:
    1. In Premiere select File -> Import..
    2. browse to images folder
    3. select First image from list
    4. select Image Sequence and click Open:
    Changing frame rate of the clip
    by right click on clip, select Modify -> Interpret Footage:
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    and if you haven't done this yet, go to preferences/general and set the default still length to 1 frame.Click image for larger version
