I'm just getting back into capturing stuff but it's been a few years so I need some advice.
I'm capturing at 1920x1080i 25 with Huffyuv video and pcm audio. I would like to convert these files into a smaller file size that also retains the quality and is blu-ray compatible. I was thinking of using AVCHD via Sony Movie Studio 12 but I wasn't sure what bitrate to use, then I read AVCHD is NOT good for interlaced video.
What format, software, bitrate should I be using?
Where did you read that? Stay away from that site.
1920x1080i 25fps interlaced is BluRay and AVCHD compatible. You can use MovieStudio to encode for BluRay/AVCHD directly.
You can resize if you want, but resizing has a quality cost -- a little or a lot, depending on how it's done. I wouldn't use SONY to do it. Use Avisynth. To resize you have some choices:
a - deinterlace with QTGMC and resize to 1280x720 50fps progressive, which would be BluRay/AVCHD compatible, and encode.
b - deinterlace with QTGMC and resize to 720x576 PAL, then re-interlace for 25fps, and encode for standard definition BluRay/AVCHD or DVD, either at 16:9 DAR.
1920x1080 progressive 25/50fps and 720x576 25/50fps progressive are not BluRay compatible. For Standard Definition formats you should change the color matrix from BT.709 HD to BT.601 SD. Do that in Avisynth, too.
https://www.videohelp.com/hd#tech
https://www.videohelp.com/dvd#techLast edited by LMotlow; 18th Dec 2015 at 09:50.
- My sister Ann's brother
How to convert Blu-ray to standard DVD?
By rocky12 in forum Newbie / General discussionsReplies: 10Last Post: 17th May 2015, 14:55 -
Authoring standard Blue Ray video from AVCHD - Need general guindance
By rodrigonh in forum Authoring (Blu-ray)Replies: 1Last Post: 9th May 2013, 00:24 -
Should Vegas Pro be able to convert a HuffYuv file to Blu-Ray format?
By brassplyer in forum Authoring (Blu-ray)Replies: 9Last Post: 5th Dec 2012, 10:27 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25
