Please recommend an easy program, for burning MKV file to blu-ray disc. I'm new to MVK files and just need a simple program to do this. Later, I would like to create a menu, etc. Thank you, in advance. Running Windows 7.
It Started In Texas
The vast majority of MKV files floating about on the net are not compliant to Blu-ray specifications. I have used MeGUI for compliant video, and Encore for menus, but Encore isn't free.
You might want to look at MultiAVCHD for making menus. -
Forget Encore. Adobe announced a while back that it has been deprecated and it is no longer for sale. Although, an Adobe CC license gives you access to the CS6 version. But I only recommend SaaS to video professionals.
Most on this forum use multiAVCHD as mentioned because it is free. Anything else will cost money: e.g. TAW5, DVD Architect, etc.
But have you browsed the list of bluray authoring software on this forum?
https://www.videohelp.com/software/sections/authoring-bd-hd-dvd -
Exactly. They're likely cropped, and the audio may be non-compliant as well.
Use MediaInfo to get the files' properties.
One way to do it:
Re-encode with uncropMKV to get compliant resolution.
Author with multiAVCHD.
If the audio is screwed, there are various ways to fix, depending on what's wrong.
But if you want easy, just author your uncropped output with tsMuxer and open with Ripbot.
(Authoring first will allow you to copy video stream in Ripbot without further re-encoding).
Select copy stream for video and re-encode your audio to AC3.
I've been able to fix effed up audio with Ripbot that defied all my other attempts.
Then proceed with multiAVCHD.Pull! Bang! Darn!
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 22:41 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Blu-ray remux (.mkv) to Blu-ray structure again ?? how
By Trigarr in forum Authoring (Blu-ray)Replies: 1Last Post: 20th Oct 2011, 09:44
