I have a bunch of TV recordings that I want to put on DVD to give to my friend. (They're MPEG2 .ts files, 544x576, 25fps)
I want to trim them down losslessly to remove the ends, so I've been using Avidemux.
Some of the trimmed videos work just fine, while others don't work: the video seems to slow down and quickly goes out of synch with the audio.
It has occurred to me that all TV recordings these came from a satellite dish, and the signal was not always 100%. On rare occasions there were "glitches" on screen. Could this explain why there are errors in trimming? (The original recordings all play absolutely fine with no errors.)
Could anyone advise please? Is there other free software other than Avidemux which can trim losslessly?
I was going to suggest video redo, but it's not free
It has a steam fix mode for this type of problem,
Fix the steam, then edit the fixed stream
Since your using avidemux, try video stream copy while recoding the audio to a different format
Then edit That file -
TSMuxer will open and remux TS files and has a trimming function.
MKVMergeGUI will do likewise and it'll open TS files, although the output will be MKV.
Neither have a preview because they're not designed for editing as such, but they should be able to remux and split/trim without messing with the audio sync.
If ultimately you want to re-encode, eac3to might be worth a shot if you have problems. It can be used to extract the video and audio streams and it'll try to fix any problems it finds in the process (audio gaps etc). The extracted video and audio can then be remuxed together with programs such as TSMuxer or MKVMergeGUI. The HdBrStreamExtractor is a fairly easy to use GUI for eac3to. The most recent version can be found here, or it's built into MeGUI and can be found under MeGUI's Tools menu.
AVIDemux how to synch and will .avi(s) work on DVD player? (details below)
By tapir2 in forum Video ConversionReplies: 5Last Post: 2nd Mar 2013, 11:45 -
Files don't play right after encoding with Avidemux.
By ROBO731 in forum Video ConversionReplies: 13Last Post: 11th Nov 2012, 00:12 -
Mpeg edited with Avidemux won't play in Pinnacle Studio 7? Please help!
By pf4711 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2012, 12:37 -
Avidemux cropped wmv goes too fast
By Jake11 in forum EditingReplies: 5Last Post: 19th Jan 2012, 17:12 -
why does Avidemux play back files faster or slower
By mukluk909 in forum EditingReplies: 1Last Post: 2nd May 2011, 12:26
