I have a 720p HD MP4 file. Since it is in a non Blu-ray compliant aspect ratio (1280 x 544), it will have have to be re-encoded in the process of converting it to Blu-ray format with BD-Rebuilder.
My question is this: would it be better to author the Blu-ray in 720p resolution, or to upscale it to 1080p (using BD-RB's "Resize - 1280 x 720 to 1920 x 1080" option)?
Also, the file has a 320 kbps AAC audio track, which BD-Rebuilder has automatically converted to a 192 kbps AC3 file (during the preliminary pseudo-BD conversion process). I tried checking the "Use 448 Kbs for AC3 encoding" option, but it still converts the file into 192 kbps. Will this result in a significant loss in audio quality?
You say that you have a 720p mp4, but the aspect ratio is actually 1280x544? So maybe you really mean you have a 544p mp4? Which one is it?
If the video is 1280x720 then it is already bluray compliant assuming the fps is as well. So you won't get any benefit from upscaling to 1080p. Just leave it as is.
I used Hybrid to convert the audio to 448 kbps AC3, then used BD-Rebuilder to author the Blu-ray in 720p. The result looks very good. Thanks to everyone for the advice.
4k upscale
By Eagleshadow in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2015, 09:18 -
Using Nuke to Upscale
By SameSelf in forum Video ConversionReplies: 11Last Post: 31st Aug 2015, 14:52 -
How do I upscale with nnedi3_rpow2?
By cathodicPen007 in forum Newbie / General discussionsReplies: 19Last Post: 24th May 2015, 20:57 -
How to upscale with Nnedi3?
By VideoFanatic in forum RestorationReplies: 24Last Post: 21st Feb 2013, 14:16 -
Few questions: Upscale SD to HD?
By nic3 in forum Video ConversionReplies: 5Last Post: 9th Jan 2011, 09:32
