Have a video which is very bright and has low contrast which makes for bad quality viewing.
Is there an editing program (hopefully basic as some editing progs are very complicated for novices) to fix that kind of problem?
You could try changing the video settings in VLC, MPC-HC, or whatever your computer player is. Or you could try and change the settings of your TV for better viewing.
But as far as re-encoding the video with better contrast and brightness, I don't know of any easy programs. Most of the easy programs don't let you mess with the color. Only thing I can think of is Tweak() in the Avisynth, which can be difficult for newbies. MeGui or AvsPmod are good GUIs for Avisynth. -
Avidemux always seemed to mess with my colors back when I was a novice, so I stopped using it. Virtualdub would be a better option.
Is it possible to adjust contrast or brightness without reencode
By ConanEdogawa in forum Newbie / General discussionsReplies: 13Last Post: 28th May 2015, 09:11 -
How to adjust the brightness and contrast of a video in Sony Vegas ?
By kwanami in forum EditingReplies: 5Last Post: 16th May 2015, 22:41 -
Adjustin brightness, contrast and color
By Martin S. in forum Newbie / General discussionsReplies: 0Last Post: 26th Dec 2013, 16:43 -
Video to Video v2.9 Filters, contrast, brightness etc
By zhen in forum Video ConversionReplies: 0Last Post: 25th Mar 2013, 18:56 -
Contrast/Brightness editing for .WMV video files
By ralphjuden in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2012, 10:35
