Hello
I'd like to convert a .ts-file from a DVB-S2 recording (french channel W9 HD) to a mkv file and somehow keep the DVB (they are bitmap subtitles, not teletext ones!) subtitles optional.
Usually this works with ffmpeg in such a way:
With the recording I have this also works so far, but from the moment on the dvdsub encoder has been chosen, the subtitles aren't in the correct position any longer. Instead they are in the upper left part of the picture. It guess the subtitle were be at the correct position in case the frame was 720x576 and not 1920x1080.Code:ffmpeg -i inputfile.ts -map 0:1 -map 0:2 -map 0:3 -vcodec copy -acodec copy -scodec dvdsub outputfile.mkv
If someone has a hint on how to get the subtitles in the right position please help.
I want your help: Change subtitle position
By mmkk in forum SubtitleReplies: 2Last Post: 31st Jan 2014, 18:35 -
Using ffmpeg, can I burn in subtitles directly from an mkv subtitle track?
By raphael_is_red in forum Video ConversionReplies: 1Last Post: 31st Aug 2013, 04:06 -
DVB to DVD with DVB subtitles and chapters
By havema-1 in forum MacReplies: 1Last Post: 19th Feb 2013, 13:37 -
Subtitle Horizontal position using tsmuxer and 4:3 MKV video
By ghostdog877 in forum Video ConversionReplies: 0Last Post: 18th Jun 2012, 22:57 -
By ghostdog877 in forum SubtitleReplies: 0Last Post: 18th Jun 2012, 22:10
