    Dec 2015
    London
    Hi there guys,
    I have an old VHS camcorder which i want to connect upto my HD TV. The camcorder only has one connection socket which says AV OUT. It also has an accessory with it which says RF Unit.
    I have attached pictures. Any help on which cables i require to connect the camcorder upto the TV to view the video will be greatly appreciated.
    Regards
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    RF out on the JVC box to ANT IN?
    Should be an old "Wall to TV/VCR" cable like the Old Days.
    We still use those here in Germany. Ours are one-way as opposed to US threaded two way.
    Dec 2015
    London
    Hi hech54,
    I tried doing that. I connected it as you have mentioned above but i do not get a picture.
    After you connected the RF OUT to your TV's Ant In, did you tune your TV to pick up the channel?
  5. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Yeah, push the switch on the "JVC RF Unit" to "Video" and tune to channel 3 or 4. Assuming Euro stuff works similarly to Yankee stuff.
    May also have to change between "antenna" and "cable" in the TV's menu?
    Dec 2015
    London
    Got it working guys. Thanks alot. The switch was on TV and then when i switched it to Video then the picture came.
    Dec 2015
    London
    Is it possible to add video attachments to threads?
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I'd just stick it here and share the link:
    https://vid.me/
