Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Oct 2015
    I wasn't getting many responces at D9 so I'm trying here.
    This sample shows a really bad case of stairstepping:
    http://www.dcresource.com/reviews/canon/powershot_s90-assets/MVI_0349.MOV
    Looks even worse in motion. I've only succeeded in calming it down a little with:
    santiag()
    Oct 2005
    666th portal
    really not much you can do once it's recorded. there used to be a filter that worked slightly in photoshop called noise ninja, but that's about all i can recall. it's a problem for still cameras with large sensors and only recording reduced resolution by combining pixels. it doesn't show up using video cams so i can't think of much work done to fix it in video editors.
    if i had to depend on dslrs only for video i'd be putting these type filters in the cams. http://www.mosaicengineering.com/products/vaf/70d/main.html
