Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    May 2008
    I am confused what happening with between my Onkyo NR3007 Receiver and WDTV Live. The audio streams are connected via optical between WDTV Live and Onkyo Receiver. I set WDTV Audio to optical pass through.
    According to the Receiver specs it does not support AC3 but supports AAC directly.
    I downloaded several .mkv movies with an AC3 - 6 ch audio stream . Since my receiver could not handle AC3 , I promptly converted the audio streams to AAC .
    Here is the issue:
    I get no sound output from the receiver using the converted AAC audio streams . But when I switched to the original AC3 sound streams I do get sound .
    Can someone help me to understand whats happening. Tks
  2. Member Cornucopia's Avatar
    That receiver may not explicitly support AC-3 (aka Dolby Digital) FILES, but it certainly implicitly supports both AC-3/DD and DTS (and their better cousins) as STREAMS.
    Your WDTVLive is streaming the audio (via the optical port, as well as via HDMI). The receiver sees the AC-3 stream and decodes it. BTW, optical ports can support LPCM stereo, as well as compressed formats which can fit in the LPCM stereo bandwidth (IOW, 2ch * 48kHz * 24bit = 2304kbps). So clearly DSD, LPCM surround, and usually other lossless surround formats cannot fit. Also, some lossy formats that are > 2304kbps cannot fit. Plus, if the receiver doesn't expect the optical/spdif/toslink to provide other formats, it won't decode them.
    My guess is that your 6ch AC-3 stream is ~640kbps, so that works great as a streamed output via either HDMI or optical. Since that receiver clearly can decode AC-3/DD, there is no problem with it coming from the WDTVLive box as a stream. Should you try to put it on a USB storage and play it directly from the app in the reciever, you might find it has difficulty there.
    You converted your AC-3 to AAC, but it could have been non-standard in some way, plus it could also have been left as 5.1/6 ch surround, instead of being downmixed. Since ALL the formats on page 124 of your manual that the receiver supports (incl. MP3, FLAC, AAC, OGG Vorbis, WMA/WMALossless, and LPCM) only allow for 2ch/stereo playback, that would explain the AAC not working. Plus, those are again FILES that it supports, not necessarily STREAMS (it isn't clear what streams beyond the standard LPCM/AC-3/DTS... are supported).
    May 2008
    Thanks for a good explanation.
    Since the Onkyo Receiver can implicitly support AC-3 as streams I will not bother with the extra process of converting to AAC . I reread the manual on Audio formats supported and definitely did not read it properly previously because it states clearly for 2 ch only. How careless of me. Yes I did leave the encoded AAC stream as 5.1/6 ch which is why it did not work.
    I may just convert one movie to AAC audio but downmixed to 2 Ch Stereo just to check it out.
  4. Member Cornucopia's Avatar
    Good idea (checking it out). Yes, extra conversion means re-encoding and since it is to another lossy format, that means some more (though likely minor) loss of quality. Best to avoid if possible.
    Good luck,
