    Oct 2011
    Mexico
    Could someone help me by creating a good avisynth script for this DVD source:
    https://www.sendspace.com/file/h8pjzo
    So far, the results are:
    script used:
    https://www.sendspace.com/file/9s9e19
    video result sample:
    https://www.sendspace.com/file/5u24y3
    Any advice on how to improve quality?
  2. firefox reports that page is not safe if attempting to download avs script and resulting file
    Oct 2011
    Mexico
    My "firefox" doesn't. Are you sure you press the right "download" button in Solidfiles?
    Press the "direct download lik".....
  4. No warning from Firefox here either, although the direct download link opens a new tab containing ads (when I disabled UBlock Origin).
  5. Banned
    Feb 2013
    When I downloaded the AVS script I got an executable (.exe)
    Virustotal scan of it
    https://www.virustotal.com/en/file/907b497c938bc7992db8528bbf9cd6403c577bbef39554cecfb...is/1449875465/
  6. Member Cornucopia's Avatar
    You are deceiving yourself if you think using a 10bit codec setting is going to somehow magically improve a title whose original copy is 8bit 4:2:0. Barring additional NR/creative processing (which generates high precision intermediates), those extra 2 bits would be wasted (possibly not compressionwise, but certainly compatibility-wise).
  7. Originally Posted by gonca View Post
    There's a second, less obvious text link for downloading the original file (avs script in this case). I don't know whether it's by design, but for me it doesn't work the first time I click on it, but it does the second time. Mind you there must be better sites for hosting files that don't try to inflict crap on you.
    Oct 2011
    Mexico
    The only reason for encoding in 10bit is to avoid as much banding as possible...
    Thanks for the compatibility-wise advice, but I watch everything in my laptop.....
    Any advice about the video? Tell me if you like about 8bit solutions.......
    Edit: links updated
