I'm still quite the noob on all things video - can someone tell me, if you have a standard def iTunes movie download, and a Blu-ray of the same movie, and you import the Blu-ray onto your Mac at the same resolution as the iTunes file, will the video from the Blu-ray look any better than from iTunes at the same size? Just curious.![]()
riven2000
Lots of factors can go into the outcome, so there's no general way to tell without further detail. Resolution is not the only determiner of quality: ther's also bitrate, codec choice & settings, # of conversion generations, and any pre-processing/Noise-reduction applied.
For example: if both the Blu-ray and the iTunes clips were encoded optimally from the original HiRez Hollywood master, by a professional compressionist, then to take a Blu-ray and make a 2nd generation copy would very likely NOT look as good as the 1st generation iTunes clip (assuming same rez, framerates, bitrates, codec...), because there will be additional DCT blocking artifacts built up in the re-encode.
So, IT DEPENDS.
Scott -
But in general, online streaming sites don't start with the original hi-res sources, use low bitrates and crappy encoders. So you can most likely get better results yourself from a Blu-ray rip.
Converting a sample video file of any resolution to 13000x1080 resolution
By user321 in forum Video ConversionReplies: 6Last Post: 6th Jul 2015, 07:21 -
Hello, a question about resolution and video quality.
By Arator95 in forum Newbie / General discussionsReplies: 23Last Post: 26th Mar 2014, 09:32 -
Video Resolution vs. Desktop Resolution question
By slipd in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2014, 07:17 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36
