  1. After a suggestion on another thread I am going to but some DVD-9 discs
    I have always bought DVD-5 discs as DVD-r
    Is there any reason to choose DVD-r or DVD+r in 8.5GB size ...... is either format better supported across most DVD players?
    There is certainly a lot more of the DVD+r on sale.
    Nov 2003
    West Texas
    Buy +R DL DVD's. The +R discs are superior, though you have to buy the right kind. The only +R DL discs that are widely available I would recommend are the Verbatim AZO variety. Here is an example at Amazon.
    FTI/Falcon also make DL +R discs using the same 2P process that Verbatim does, and they make a lot of the discs sold under the Verbatim brand, but it is much harder to find the FTI discs. The Verbatim discs should be easy to locate.
  3. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Yes, "+" is superior - better burns, better on sessions, and this applies to RW as well, etc. It came later than "-", hence the enhancements.
    You did ask about being supported though, so therein lies the (really only) advantage of "-" because it came before "+". It is indeed the common denominator of compatibility of all discs in this regard. Any unit that runs "+" will run "-", but not (theoretically) vice versa.
    However, this advantage is now less and less relevant. If this was like ten years ago, say like in 2005, I would much more recommend "-" because of this.
    I hate VHS. I always did.
  4. Thanks .. I'll go buy a pack
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    -R Verbatim or Taiyo Yuden for single layer.....+R for dual layer(Verbatim) simply because there really is no other choice for D/L except +R
