I have an .mkv file with both 5.1 and 2.0 audio tracks. I want to remove one of them to lower file size. Now, will 5.1 give a worse experience on standard 2 speakers setup than 2.0 track? Or is it better than 2.0 in every way?
Hypothetically speaking, a mix optimized for 2.0 playback on 2 speakers should be slightly/somewhat better than a 5.1 mix automatically downmixed to those same 2 speakers. In practice, I doubt many consumers could tell the difference.
So, I recommend you drop the 2.0 and keep the 5.1 (assuming the program content is supposed to be the same).
Scott -
Usually, if you have both 2.0 and 5.1 audio tracks the movie was originally stereo (maybe even mono) and the 5.1 track is some up-mix that's there to impress people who think bigger numbers are better.
I think that depends greatly on the source. Most original releases I've seen this way have actual intentionally different mix balances (both good). It's just someone's re-post who tries to up-mix, and usually (as you said) for the wrong reasons. Up-mixing rarely works well anyway.
PC speakers & TV Speakers At The Same Time
By TheRandomOne in forum AudioReplies: 0Last Post: 6th Oct 2015, 11:20 -
Question how to keep StreamTransport capture audio off the speakers
By jimdagys in forum AudioReplies: 2Last Post: 9th Mar 2014, 20:59 -
ffmpeg to capture audio from speakers?
By p3aul in forum AudioReplies: 3Last Post: 23rd Jun 2012, 17:35 -
PC speakers 1sub/2 speakers, possible to add 4 more to set?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 20th May 2012, 00:55 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 20:51
