EDIT: S-Video cable was damaged, tried another & it works however the image from my VCR is constantly scrolling downward & amcap gives me an error: http://s28.postimg.org/6pj0yrh25/Composite.png No scrolling or any other issues occur when the VCR is hooked up to my television. VCR is JVC HR-S3500U.
I did install a new graphics card before these issues. Don't know if that's related but I doubt it because my Hi8 camcorder has no issues with the capture card or gpu.
Any thoughts?
Results 1 to 16 of 16
It says 640x480 at 25Hz. Mixing NTSC frame size with PAL rates could be the issue. Set it to the same resolution but at 29.97 fps and see what happens. If the VCR is from the US.
I don't know how to change fps settings. The VCR is from Canada & I get the 'best' results with NTSC in amcap: Scrolling in stop mode, but while playing a tape it's very jittery with the colour going & coming randomly. Pal settings show the video completely scrambled in black & white, so I'm guessing it's not an issue with NTSC vs PAL. I've tried every possible combination of settings in amcap + the VCR's menu with no success. Very confused (though I am not overly experienced in this area).
Interestingly, I just tried running my Hi8 camcorder through the input of the VCR to the capture card & the image showed up completely fine without any issues on amcap... Yet when I unplug the camcorder & the image returns back to the VCR itself, it continues to scroll.
Macrovision - http://www.mediacollege.com/video/editing/macrovision/
or defective VCR. -
I have the Philips clone version of your VCR, but PAL of course and added TBC.
If you are talking about factory-recorded Hollywood made VHS tapes......no. Macrovision is Macrovision.
He showed that the VCR-generated blue screen itself displays incorrectly. That wouldn't be Macrovision.
But VCR menu screens don't seem to comply with the typical video standards, so this issue could be completely separate from the problem with tape playback. These cheap capture devices just can't handle sources with unstable timebase, it seems.
At 3:00 this guy shows it:
I haven't actually experienced Macrovision myself in many many years....and have never experienced it during capturing....only ever saw it in action back in the "old days" with my Philips DVD recorder.
Could this VCR he has be one of those quasi S-VHS models.....what did they call that again?....I forget.
Oh yea....S-VHS "ET" maybe?
EDIT: Nope...mine says ET too....DUH.
That's what my tape looks like as well through the Sabrent. I still wonder why running my hi8 camcorder through the VCR shows the picture fine?
I guess I'll look for a different capture device or find a used DVD recorder.
Thanks for the responses. -
The Hi8 camcorder may have a TBC that's turned on, or may simply be a more stable recording.
Can't get signal from HDMI on video card in Windows
By sdsumike619 in forum ComputerReplies: 20Last Post: 28th Aug 2015, 19:37 -
Capture the WiFi signal from video camera, with Android
By windranger in forum Capturing and VCRReplies: 0Last Post: 25th Oct 2014, 03:26 -
No signal at all from Hauppauge Colossus Capture Card
By Rizz1337 in forum Capturing and VCRReplies: 9Last Post: 6th Sep 2012, 00:05 -
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
Sabrent Video DVD Maker Video Capture Creator Anyone?
By Rayj00 in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2011, 11:10
