Everytime I convert the file in TMPEng it comes back as full screen version. The format of the file is 2.35:1 and there is no setting in the advanced tab to change to this. Any suggestions?
Don`t know if this is the best sollution but works for me.
When you encode to Mpg in TMPEng there are two options you want in the advanced tab, they are Source aspect ratio and Video arrange method. It`ll take some testing to get the best results but I use 16:9 or 2.11:9 in Source aspect ratio and Full screen (Keep aspect ratio 2) in the video arrange option but you can use a custom setting but it`ll depend on your dvd player playing a non standard disc. Mine will play a SVCD set to 576*432 so I can keep the full 240 vertical lines of the film that I had.
Best to do a few tests and see what looks best
Hope this helps
Using widescreen format
By SearchQuality in forum EditingReplies: 6Last Post: 9th Jan 2012, 16:05 -
Widescreen back to 4:3 format
By Acemon in forum Video ConversionReplies: 2Last Post: 22nd Feb 2011, 22:29 -
DVD Recorder Widescreen Format
By TLA in forum DVD & Blu-ray RecordersReplies: 11Last Post: 30th Jan 2010, 09:25 -
re-encoding vid file for smaller size but keeping same format?
By WidowMaker in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 13:56 -
Difficulty In Converting .Vob to Any Format & Keeping Widescreen
By RachelArcher in forum DVD RippingReplies: 50Last Post: 10th May 2008, 10:40
