I'm converting my DVD library to MP4s using Vidcoder. All of my DVD's are lectures, sermons, and old TV programs that have been converted to DVD from VHS. So, since these aren't movies, they don't show in HD. Visually, will it make a difference if I use the mp4 codec vs h.264, and would you recommend me doing such? I only ask because it's MUCH quicker to rip using the mp4 codec and I have hundreds of discs to rip so saving time would be great.
				Results 1 to 10 of 10
	mp4 is not a codec, it is a container. It usually contains h.264. Try converting a short section of your disc using each setting and see which looks better. Tweak from there.
	It says MPEG-4 not MP4 as codec, ie h.263/Xvid/Divx. It's not as effecient as h.264 for compression, ie larger file for comparable quality, but as suggested run some test for short sections. I often prefer MPEG-4 as I find the picture "softer" than h.264 encoded with x.264 - but you find your preference.Vidcoder gives the option of H.264 or MP4 as the choice codec
	Aside from previous comments:
 To "rip" does not mean to re-encode. A rip is a 1:1 copy, sometimes requiring decryption, but it's not re-encoding. What you are doing is rip + re-encode.
 If your videos are SD, they'll be SD when they're re-encoded. h264 does not automatically make it HD, and re-encoding in itself doesn't improve anything. More often, lossy re-encoding is a quality loss, more or less depending on how it's done.- My sister Ann's brother
	I use VidCoder quite a bit for DVD conversions to MKV. With my PC, I just convert directly from the DVD in the optical drive instead of ripping. Saves time.
 For commercial DVDs, I use set Detelicine and Decomb filters to default. Constant quality at 19.5 and constant bitrate. Audio to AC3. All else to default settings.
 You can use a higher CQ number if your source video isn't that good.
 It takes about 12 -15 minutes per DVD conversions. It helps if you have a couple of optical drives. I have three. I've converted over a hundred DVDs so far. No problems.
  H.264/MP4 codec ?By Tafflad in forum Newbie / General discussionsReplies: 88Last Post: 11th May 2014, 18:25
  Mp4 codec conversion to compatible codec formatsBy prath in forum Video ConversionReplies: 4Last Post: 31st Jan 2014, 07:44
  Demux MKV/h.264/AC3-5.1 to MP4/h.264/AC3-5.1 (using MP4tools / mkvextract)By xnu in forum Video ConversionReplies: 2Last Post: 17th Jun 2012, 07:42
  corrupted .mp4 h.264By bluesky1 in forum Software PlayingReplies: 8Last Post: 1st Jan 2012, 16:22
  Where to get Functional h.264 codecBy thunderpanda in forum Video ConversionReplies: 6Last Post: 26th Dec 2011, 00:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
